Reload this Page >
Skymaster 1:7.5 F-4 Phantom
Old 08-01-2018, 01:50 AM
  #76
kwik
kwik's Avatar
Default What's the fuel capacity?
Could anyone please tell me the total fuel-capacity of the 3 tanks in the 1/7.5 SM F4?
I've been looking for a manual on the net, but noone to be found.
Trying to set a reasonable number in the timer on the transmitter.
Old 08-01-2018, 02:31 AM
  #77
tp777fo
My Feedback: (28)
tp777fo's Avatar
My saddles hold 56oz each, msin 80 oz. Total 192oz.
Old 08-01-2018, 03:04 PM
  #78
tp777fo
My Feedback: (28)
tp777fo's Avatar
What retract valves do you guys use. Im having trouble with mine retracting. Jettronics dual action.
Old 08-01-2018, 09:42 PM
  #79
ozief16
My Feedback: (13)
I’m using a BV Hi-flow valve for the gear. Never had a problem. The doors are actuated by a single action valve to close and they are T’d into the gear down lines to open them
Dave
Old 08-02-2018, 03:52 AM
  #80
tp777fo
My Feedback: (28)
tp777fo's Avatar
Thanks!
Old 08-02-2018, 04:09 PM
  #81
JDjetjock
JDjetjock's Avatar
I use the JMP high flow valve on the mains, a robart one on the nose and the stock Skymaster valve on the doors. I have separate air systems for the gear, doors and brakes! Air tanks are light,so there are five of them in my F-4.
Old 08-05-2018, 06:39 AM
  #82
kwik
kwik's Avatar
Thanks.
192 oz should be = 192 x 33 grams = 6336 grams
And many says it burns 580 grams / minute at max rpm.
That should give 6336 / 580 = 10.9 minutes at max rpm. Maybe I set the timer at ......7 minutes for first fllight.
I am close to the maiden now.
After reading through this thread, I will try it with CG at 320 mm according to this drawing here;
It has been flown once before by the previous owner with the CG at this point, but he didn't use flaps for landing.
Old 08-05-2018, 07:55 AM
  #83
kevinthoele
You will want to use flaps for landing. At this cg it will fly but still be nose heavy. Don’t be afraid to start at 330 or 340 and use flaps for take off and landing
Old 08-05-2018, 02:36 PM
  #84
tp777fo
My Feedback: (28)
tp777fo's Avatar
This a labor of love. Another flight today after gear repair. Good news....all gear retracted and extended. Bad news...blew off one main door, broke the other and 1 inner door didnt close all the way. Overall successful and an improvement from last flight. Will repair the main doors tomorrow with a strap around the strut, move the ram for the inner door and I may just remove the outer doors. Not planning on competition just fun. Plane flies well but gear has been a PITA.
Old 08-05-2018, 04:21 PM
  #85
ozief16
My Feedback: (13)
Tom,
i changed the inner main gear door actuators to BV cyl and changed the geometry a lot and they’re great now. Stock never worked. My mains middle door was attached to the gear leg with some G10 brackets that hold it quite nicely. I can send pics later if you need. The outer main doors seem to close ok even up to 200mph...ops checked
swap cyl to the BV ones and set geometry different and it’ll make you much happier!!
I know EXACTLY how you feel
Old 08-05-2018, 04:25 PM
  #86
ozief16
My Feedback: (13)
You can see they’re all closed if you zoom in on this. Not a fast pass, maybe 150
Dave
Old 08-05-2018, 07:21 PM
  #87
yeahbaby
My Feedback: (21)
yeahbaby's Avatar
DUDE! Look at those tail cones! Sooooo coollll and much better looking than the stock fiberglass ones!!! Where’d you get them....and who was the inspiration?
cmon let’s hear it.....who’s better looking? Cmon you can say it, we all know.
Baahhaaahhaa. Beeches
Old 08-05-2018, 07:24 PM
  #88
ozief16
My Feedback: (13)
Yes yes Buck: you’re pretty. I’m ugly. You’re smart. I’m dumb. You were right and I was wrong
haooy now!?
ps-you we’re right...damn I lost the bet!!
Old 08-05-2018, 07:29 PM
  #89
yeahbaby
My Feedback: (21)
yeahbaby's Avatar
LoL
Old 08-06-2018, 04:06 AM
  #90
tp777fo
My Feedback: (28)
tp777fo's Avatar
Dave that is one good lookin jet. I will keep working on mine till I get it right. After I get ut all figured out I may just get a new one that will look real good. You going to SJS?
Old 08-06-2018, 02:45 PM
  #91
ozief16
My Feedback: (13)
Tom, thank you. I worked hard on that one. It’s done up in my dads jet’s scheme as best I can do with his name and his WSOs name/number etc.
i doubt ill make SJS..certainly I won’t have a jet if I make it unless Gottschang lets me bum a ride again!!
Keep after it. It’s a cool jet but takes a bit of work to make an everyday plane
Dave
Old 08-06-2018, 03:33 PM
  #92
roger.alli
roger.alli's Avatar
Dave
Damn that looks good Dave!! Great work!! Especially on the belly surface.
I don’t think these models are ever going to be “every day” fliers.. They are just too complicated. And then there is all the time invested.
Old 08-06-2018, 04:27 PM
  #93
ozief16
My Feedback: (13)
Thanks Roger. I really enjoyed the weathering of this beast.
I’ll start the Hun in the next month or so. Very excited and will be picking your brain I’m sure. Right now the question is: can you PM me more about how you did aileron connections on the Hun? Yours is far lower profile than stock
thanks
Dave
Old 08-06-2018, 06:11 PM
  #94
Ad Clark
Ad Clark's Avatar
NICE work Dave!!!!--Ad
Old 08-07-2018, 05:28 AM
  #95
tp777fo
My Feedback: (28)
tp777fo's Avatar
Not pretty but it should hold strut door on. Just like the real thing....1 flight and a week of maintenance.
Old 08-07-2018, 05:41 AM
  #96
tp777fo
My Feedback: (28)
tp777fo's Avatar
Piece of dog food can to touch magnet. Hope it will help hold door shut.
Old 08-07-2018, 08:08 AM
  #97
yeahbaby
My Feedback: (21)
yeahbaby's Avatar
It will work. I did similar but went magnet to magnet. Use tiny rare earth magnets. It can be an everyday flier amigo, I did numerous reinforcements throughout my build and flew it more than my Kingcat. Loved it and you will too. Not many airplanes can compare to a Phantom turning final approach calling the ball at a 1/4 mile. Thing of beauty.
Old 08-07-2018, 08:27 AM
  #98
ravill
ravill's Avatar
Amen, brother!
Wow, those shots of that Phantom are jaw dropping!
Old 08-07-2018, 07:51 PM
  #99
kevinthoele
It for sure can be an everyday flyer. Mine has been awesome. So much so I have another coming
Old 08-07-2018, 08:32 PM
  #100
ozief16
My Feedback: (13)
Tom, I’m with Kevin and buck but it’ll take some work to get it there!!
Dave
