Reload this Page >
New Sport Jet: T-One Models Mini Fortune / Mini T1
Old 10-07-2017, 05:18 AM
i3dm
My Feedback: (51)
Originally Posted by markusvt
Link to the sleeving you bought?
Heat resistant sleeves
Old 10-10-2017, 11:29 AM
i3dm
My Feedback: (51)
Very neat feature is this tube in the wing to pass the cables forward so the wires exit far from the turbine's heat.
Old 10-10-2017, 11:30 AM
i3dm
My Feedback: (51)
Fuse to Wing harnesses - color coded
Old 10-10-2017, 11:31 AM
i3dm
My Feedback: (51)
Harnesses routing in fuselage
i3dm
My Feedback: (51)
FCT UAT piggy backed on the Fuel Tank.
ID:	2240784   Click image for larger version
Old 10-10-2017, 11:32 AM
  #31
i3dm
My Feedback: (51)
Wing Servos installed.
ID:	2240786   Click image for larger version
ID:	2240787   Click image for larger version
Old 10-10-2017, 11:47 AM
  #32
DrScoles
My Feedback: (18)
DrScoles's Avatar
Originally Posted by i3dm
Piggyback for the FCT UAT all done
LOL, I just 3D printed a very similar bracket for my Mig-15 UAT
Old 10-10-2017, 11:51 AM
  #33
grolleman
nice
Old 10-12-2017, 02:27 AM
  #34
i3dm
My Feedback: (51)
Engine wiring complete
Old 10-12-2017, 02:28 AM
  #35
i3dm
My Feedback: (51)
Fuel System almost ready
Old 10-12-2017, 02:31 AM
  #36
i3dm
My Feedback: (51)
Fuel Vent 6mm
Old 10-12-2017, 02:47 AM
  #37
i3dm
My Feedback: (51)
Very Nice Mike.
the FCT UAT actually comes with the brackets and they have several types - all stock so its easy
Old 10-12-2017, 01:43 PM
  #38
i3dm
My Feedback: (51)
Front Tray layout before...
Old 10-12-2017, 01:46 PM
  #39
i3dm
My Feedback: (51)
Front tray complete!
On the Tray:
JP gear controller
Cortex Gyro
Futaba R7008 Rx
DPSI Ampere by Emotec
Cortex Gyro is connected via Sbus to Rx, and outputs 7 chanels (5 stabilized and 2 pass through).
The Rx has 7 more PWM channels so its an easy 14 channel setup with full telemetry out of this R7008SB receiver!
RTDT (Radio and micro Turbine Data Terminal)) - my own design
Old 10-13-2017, 06:02 AM
  #40
i3dm
My Feedback: (51)
Checking the CG using Daniel Maiorano's CG Wizard was a breeze!
Dirk from Pacific RC Jet recommended 200mm, to get there i had to move batteries way back !
ID:	2241090   Click image for larger version
ID:	2241091   Click image for larger version
Old 10-13-2017, 06:04 AM
  #41
i3dm
My Feedback: (51)
Creative mounting for both turbine battery (Life 9.9V 2300mah) and twin Rx batteries (2 x 6.6V Life 1100mah)
ID:	2241093   Click image for larger version
ID:	2241094   Click image for larger version
ID:	2241095   Click image for larger version
ID:	2241096   Click image for larger version
Old 10-14-2017, 04:54 AM
  #42
i3dm
My Feedback: (51)
Rx battery harnessed are made from 16awg silicone wiring and Deans plugs with end fittings - very easy to fit and disconnect
Also, Rx packs have been labelled.
ID:	2241179   Click image for larger version
  #43
i3dm
My Feedback: (51)
Emcotec Magnetic Switch running perfrctly!
Old 10-14-2017, 04:55 AM
  #44
i3dm
My Feedback: (51)
Futaba Rx antenna installation.
antennas are held in 4mm PU tubes with heat shrinked tips.
90 degrees between antennas.
Old 10-14-2017, 04:57 AM
  #45
i3dm
My Feedback: (51)
My own design RDT telemetry for Kingtech G2 ECU and Futaba radio running perfectly.
and my own design Micrro Data Terminal for Kingtech G2 ECU shows all turbine data at under 5 grams weight!
ID:	2241183   Click image for larger version
Old 10-14-2017, 04:59 AM
  #46
i3dm
My Feedback: (51)
All pushrods connected and turned to size. all stock hardware pictured!
TOP: centering servos with a servo tester while building saves you A LOT of time in the final setup stages!
  #47
i3dm
My Feedback: (51)
Adding some color with the markings
ID:	2241186   Click image for larger version
Old 10-14-2017, 05:00 AM
  #48
i3dm
My Feedback: (51)
Here she is 100% complete!
all there is left now is to tune the control deflections and test fuel system / turbine.
Old 10-17-2017, 03:17 AM
  #49
i3dm
My Feedback: (51)
Ready To Fly !
knpjdad (06-14-2022)
Old 10-17-2017, 08:13 AM
  #50
Chris Balling
Chris Balling's Avatar
Smile
Finally; it was a George Strait day (Blue Clear Sky) in Arizona, so we took the drive to our world famous lake bed north of Kingman to maiden our "Mini". A very cool morning (47f) by southwest standards, the K-70 roared into life and the newest addition to our stable smoothly rotated into the air. A first occurred in my many years of jetting, absolutely no trim required. Not using more that 1/2 throttle (remember, cool temps) the flight was enjoyable from the very beginning. My maiden shakes quit as soon as the gear came up and an effortless 6 minute flight was fun and relaxing. Inverted flight demonstrated a perfect balance (middle of the wing tube), and loops as big as you like to make them. With no wind, the smoke simply hung in the air. Time to land: Half flap (one click elevator in flight mode), Full flap, one more up click on Elevator. A landing pass, then an uneventful landing; nose up, power on, touch the mains, idle power and the nose wheel touches surface........no brakes necessary as it's a hard, but dirt surface. YAHOOOOOO. Check the fuel: Half a tank remaining. Wow, this little 70 is truly powerful and fuel efficient.
ID:	2241462   Click image for larger version
ID:	2241463   Click image for larger version
