Reload this Page >
New Sport Jet: T-One Models Mini Fortune / Mini T1
Old 10-17-2017, 08:28 AM
  #51
DrScoles
My Feedback: (18)
DrScoles's Avatar
Awesome Chris, Did you have to put the batteries far back like Lior did?
Old 10-17-2017, 08:39 AM
  #52
grolleman
beautiful built
And also very fast.
Have fun with your new plane
Old 10-17-2017, 10:05 AM
  #53
Chris Balling
Chris Balling's Avatar
Many thanks to you for your kind words and PM's. I'll try to answer your questions. My batteries are all located over the nose wheel well. I use Industrial Strength Velcro on both the a/c and battery surfaces, then a single wrap to ensure that all three stay intact during any negative G maneuvers. The flying surfaces have a great deal of authority. As an old pattern flyer, and long before EXPO had even been thought of, I still use rates. Generally, take off at Mid Rate, wheels/speed up go to switch to low, and back to mid for landing. I found that the low aileron rate of 3/8" was perfect for my style. Elevator 1", and 1/4" on rudder was perfect for slow and point rolls. This air-frame has 0 coupling. Steering is very sensitive, so you need very little steerage once the plane is in motion. My smoke pump is a BVM (Sorry Dirk, it was sitting on the bench). I agree with all of you who say this is a superbly painted and a quality airplane. It's performance in the air is also superb............
Old 10-17-2017, 10:49 AM
  #54
DrScoles
My Feedback: (18)
DrScoles's Avatar
interesting, all the reports I've read said that people had to put the batteries as far back as possible....
Old 10-18-2017, 02:18 AM
  #55
i3dm
My Feedback: (51)
Originally Posted by Chris Balling
Finally; it was a George Strait day (Blue Clear Sky) in Arizona, so we took the drive to our world famous lake bed north of Kingman to maiden our "Mini". A very cool morning (47f) by southwest standards, the K-70 roared into life and the newest addition to our stable smoothly rotated into the air. A first occurred in my many years of jetting, absolutely no trim required. Not using more that 1/2 throttle (remember, cool temps) the flight was enjoyable from the very beginning. My maiden shakes quit as soon as the gear came up and an effortless 6 minute flight was fun and relaxing. Inverted flight demonstrated a perfect balance (middle of the wing tube), and loops as big as you like to make them. With no wind, the smoke simply hung in the air. Time to land: Half flap (one click elevator in flight mode), Full flap, one more up click on Elevator. A landing pass, then an uneventful landing; nose up, power on, touch the mains, idle power and the nose wheel touches surface........no brakes necessary as it's a hard, but dirt surface. YAHOOOOOO. Check the fuel: Half a tank remaining. Wow, this little 70 is truly powerful and fuel efficient.
great job! so the flaps actually require UP elevator compensation?
this is usually an indication of nose heavy CG.
Old 10-18-2017, 02:20 AM
  #56
i3dm
My Feedback: (51)
i tried to balance at 200mm according to Dirk's recommendation.
i like pretty neutral CGs anyway so i figure for me it should be good, but will fine tune once airborne for sure.
Old 10-18-2017, 02:22 AM
  #57
i3dm
My Feedback: (51)
Engine test of the K-60G in the Little Mini Fortune went fine, started right up and ran OK!
I did notice the engine clamp sits loose on the engine body - Barry Hou from Kingtech USA was kind enough to offer a free replacement - i am waiting for that to arrive - in the meanwhile some aluminum tape on the inside of the clamp seems to hold the motor firm.
Old 10-18-2017, 03:23 AM
  #58
gunradd
My Feedback: (9)
gunradd's Avatar
Lior even 200mm might be nose heavy still. I was moving it back every flight and simply ran out of stuff to move back easily while at the event. 200 should be a nice starting spot though but I am sure it can go back more then that. I had all the batteries around the main fuel tank. The UAT was in the nose... This made it hard to move the CG back. I was going off the original factory CG and that was so nose heavy it really flew pretty bad and should never be used.
Old 10-18-2017, 05:42 AM
  #59
i3dm
My Feedback: (51)
Actually the way i have it now (main packs behind fuel tank, ECU pack right in front of tank and UAT above tank) i think im still still a few mm ahead of the 200mm mark.
when yours is without fuel, sitting on the gear, if you tilt back on the tail - does it stay sitting on the tail (nose in the air)?
Old 10-21-2017, 01:05 PM
  #60
i3dm
My Feedback: (51)
She flys extremely well for a little fella !
Video of flight #2 in Ein Yahav, Israel:
Old 10-21-2017, 01:08 PM
  #61
i3dm
My Feedback: (51)
Some Action SHots from today
ID:	2241853   Click image for larger version
ID:	2241854   Click image for larger version
ID:	2241855   Click image for larger version
ID:	2241856   Click image for larger version
ID:	2241857   Click image for larger version
ID:	2241858   Click image for larger version
ID:	2241859   Click image for larger version
ID:	2241861   Click image for larger version
ID:	2241862   Click image for larger version
ID:	2241863   Click image for larger version
ID:	2241864   Click image for larger version
ID:	2241865   Click image for larger version
ID:	2241866   Click image for larger version
ID:	2241867   Click image for larger version
ID:	2241869   Click image for larger version
ID:	2241870   Click image for larger version
ID:	2241871   Click image for larger version
ID:	2241872   Click image for larger version
ID:	2241873   Click image for larger version
ID:	2241875   Click image for larger version
ID:	2241876   Click image for larger version
ID:	2241881   Click image for larger version
ID:	2241882   Click image for larger version
ID:	2241883   Click image for larger version
ID:	2241884   Click image for larger version
ID:	2241885   Click image for larger version
ID:	2241886   Click image for larger version
ID:	2241887   Click image for larger version
Old 10-21-2017, 01:13 PM
  #62
markusvt
Nice flight!
  #63
i3dm
My Feedback: (51)
More pics
ID:	2241889   Click image for larger version
Name:	20171023-A9C02794 - Copy.jpg
ID:	2241890   Click image for larger version
ID:	2241891   Click image for larger version
ID:	2241892   Click image for larger version
ID:	2241893   Click image for larger version
ID:	2241894   Click image for larger version
ID:	2241895   Click image for larger version
Name:	20171023-A9C02813 - Copy.jpg
ID:	2241897   Click image for larger version
ID:	2241898   Click image for larger version
ID:	2241899   Click image for larger version
ID:	2241900   Click image for larger version
ID:	2241901   Click image for larger version
ID:	2241902   Click image for larger version
ID:	2241903   Click image for larger version
ID:	2241905   Click image for larger version
ID:	2241906   Click image for larger version
ID:	2241907   Click image for larger version
ID:	2241908   Click image for larger version
ID:	2241909   Click image for larger version
ID:	2241910   Click image for larger version
ID:	2241911   Click image for larger version
ID:	2241913   Click image for larger version
ID:	2241914   Click image for larger version
ID:	2241915   Click image for larger version
Old 10-21-2017, 02:31 PM
  #64
markusvt
Can you post your travel on each surface?
Old 10-22-2017, 12:21 AM
  #65
i3dm
My Feedback: (51)
Attached are the factory recommended CG and travel values.
for CG i used 200mm.
Travels are like T-One recommended but with lower flap takeoff value (about 20mm rather than 45mm) and as much rudder as i could squeeze out (much more than 22mm).
i did find i had to use a lot of Expo on the controls and A LOT of DOWN elevator mixing upon deploying flaps (this is very reasonable with close to neutral CG) - i will measure those values too and post them as soon as i can.
Old 10-22-2017, 05:39 AM
  #66
emart
I did the maiden on mine also yesterday . I have the CG at 200 and I think it can go back just a little . I also needed down elevator with flaps aerlerons where very sensitive have 35% expo
ID:	2241966   Click image for larger version
Old 10-22-2017, 10:53 AM
  #67
i3dm
My Feedback: (51)
Just installed the nose gear door on 2 simple plastic hinges.
Old 10-24-2017, 01:11 PM
  #68
i3dm
My Feedback: (51)
Nose door servo installation.
Old 10-24-2017, 01:12 PM
  #69
i3dm
My Feedback: (51)
Nose door servo operation.
Old 11-16-2017, 12:11 PM
  #70
Chris Balling
Cool, Snarky, Fast, Sierra Hotel ! All superlatives to describe the Mini T-1. Easily fits in a Mini SUV and five minutes after arriving at the field she is ready for fuel. 10 minute flights with the K-70. Nothing but pure enjoyment, and after 14 flights she looks as good as it did right out of the box. Need I mention it lands as easily as a Giant Ugly Stik! Perfect airplane for an old man.........
ID:	2245302   Click image for larger version
Old 11-28-2017, 11:29 AM
  #71
Tip22v
Has anyone flown one with a K-85? I’ve got a K-85 on the bench and a K-70 on order so I’m in the fortunate position to choose between the two turbine sizes.
What all-up ready to fly weights are you finding on the mini?
My T-1 (bigger T-1) weights 39 lbs full of fuel and smoke oil and my K140 is plenty of power, I would like to keep the mini as light as possible but I also need to be able to take-off on a 300’ asphalt strip. Thanks- Tom
Old 11-28-2017, 01:55 PM
  #72
emart
I am flying mine on a K 85 but only have 3 flights on it so far . I fly from a thick grass field and the 85 helps get it off the gorund easier .
Old 11-28-2017, 03:08 PM
  #73
markusvt
Flight time with the K85?
Old 11-29-2017, 06:04 AM
  #74
emart
I m using the smoke tank for fuel also had my timer set for 5 mins and the lower tank was still 1/2 full so could probably get 8 mins easy
Old 11-29-2017, 02:10 PM
  #75
Joe1199
Getting closer to finishing my mini T-1, I have a question though, I’m about to put the servos in the wing and tail (Savox 1250) with the mounts that come with the kit you cannot use the rubber mounting grommets, is everyone hard mounting their servos and having no issues?
cant wait to fly it now!
Joe
