Reload this Page >
Bob Cat Copy Falcon 120 Jet
Old 03-17-2019, 02:23 PM
  #4976
jetflyr
Originally Posted by airborn900
So is there a v3 or v4 then?
I was under the impression there was only 2 different versions. One had sheeted wings one didn’t.
Im obviously missing a piece of the puzzle.
There was the Falcon v1 and v2, Turbinator v1 and v2 - essentially the same. Turbinator v3 and v4 which had some carbon fiber loosely attached and heavy glass on the booms. ALL need attention to landing gear mounts, hardening the balsa blocks supporting the boom bolts, engine mount, etc. Do not get caught up in what version. They all need a fair amount of tweaking.
Greg
Old 03-17-2019, 02:59 PM
  #4977
SeaHawk-RCU
How much better out of the box is a V2 vs V1
Not much between them, sheeted wings, two attach screws per wing, That's about it from memory.
Col
Old 03-17-2019, 03:59 PM
  #4978
BaldEagel
BaldEagel's Avatar
Well in the Uk none of them had fully sheeted wings, and none where made to take a turbine, until they where re-named Kestrel.
Old 03-17-2019, 06:08 PM
  #4979
SeaHawk-RCU
Are they still available in the UK? I wouldn't mind one to keep unassembled on the shelf.
Col
Old 03-19-2019, 10:09 AM
  #4980
rjbob
My Feedback: (8)
rjbob's Avatar
Help!
Anyone have a nose gear (for Falcon 120) available? I don't need a whole gear set.
Would like t purchase.
Thanks!
Old 03-19-2019, 02:05 PM
  #4981
SeaHawk-RCU
Originally Posted by rjbob
Help!
Thanks!
I just use these. Haven't failed in normal service yet. Broke one in crash landing though.
https://hobbyking.com/en_us/all-meta...s-10-12kg.html
Col
Old 03-20-2019, 04:34 AM
  #4982
airborn900
My Feedback: (25)
Greg
What are the must do mods before you try to fly one of these?
Landing gear blocks
boom mounts
what else?
Old 03-20-2019, 04:00 PM
  #4983
SeaHawk-RCU
Landing gear blocks
boom mounts
what else?
I have previously posted pictures of the mods I have done to my Falcons.
UC mods on page 184 of this thread.
I'll see if I can find some more.
My usual mods;
UC blocks and cutouts for trailing ARM U/C legs.
1/2" aluminium angle under rear deck each side extending forward to rear fuse former.
Dremel rear fuse to locate front case of turbine at rear deck step. (CoG considerations)
Remove covering on wings,, add real glue where needed and sheet.
Remove rear fuse formers, reshape to fit conformal tank and glue in with real glue.
Remove front fuse formers and replace with new one to allow nose retract to fit deeper into fuselage. (nose gear protruded in mine)
(reference to "real glue" is a dig at the factory over the "flour and water" crappy stuff they use)
Col
Old 03-20-2019, 06:58 PM
  #4984
airborn900
My Feedback: (25)
My usual mods;
Col
thank you. I’ll head to page 184 and check it out
Old 06-05-2019, 09:34 PM
  #4985
srt10
My Feedback: (20)
is there a preferred place to buy these Falcons online?
I'm looking all over with no success
Thanks!
Old 06-05-2019, 10:23 PM
  #4986
SeaHawk-RCU
Thanks!
I have been looking for months but I cannot find any either. They were also sold under the names Navycat and Tornado if I remember correctly.
Col
Old 06-06-2019, 03:24 AM
  #4987
mongo
My Feedback: (15)
mongo's Avatar
classifieds
Old 06-06-2019, 04:04 AM
  #4988
Dieselman1220
My Feedback: (25)
Dieselman1220's Avatar
I’m not sure why but they are no longer in production.
I have one listed for sale in the classifieds.
Old 06-06-2019, 04:18 AM
  #4989
airborn900
My Feedback: (25)
I have a super falcon 120 new in box. I have the dreamworks/prolink struts for it as well as the dreamworks 5 degree engine mount. I also have a conformal fuel tank to go with it. All items are new/unused. If anyone is interested let me know, I’ll take pictures.
Old 06-06-2019, 04:21 AM
  #4990
airborn900
My Feedback: (25)
Stock photo
Old 06-12-2019, 11:15 AM
  #4991
Larrythelathe
Default Bounce
I am just about to do my second one of these. By first one really liked to bounce. That killed it in end.its not my first jet. Anyone else have this? Is it fixable?
Old 06-12-2019, 12:44 PM
  #4992
Woketman
Make it such that when at rest on wheels , it has a slightly negative incidence concerning the wing. That should prevent the bouncy-bounce.
Old 06-12-2019, 01:21 PM
  #4993
joeflyer
My Feedback: (48)
Land slower.
Old 06-12-2019, 01:53 PM
  #4994
Woketman
That too will work!
Old 06-12-2019, 02:13 PM
  #4995
Larrythelathe
Default Bounce
Negative being nose down?
to be fair it was pretty slow.
Old 06-12-2019, 03:10 PM
  #4996
Woketman
Yes, negative wing incidence = nose down. But just a degree.....
Old 06-12-2019, 06:49 PM
  #4997
CARS II
My Feedback: (7)
CARS II's Avatar
More draggggg
Old 06-12-2019, 08:14 PM
  #4998
Dieselman1220
My Feedback: (25)
Agree land slower, a big help would be crow.
add about 1/4” of up aileron and go with about 2 1/2” of flap throw.
Old 09-11-2019, 07:16 AM
  #4999
Kim Couturier
My Feedback: (120)
Wow, long thread! I have a question. I have a chance to pick up a red falcon 120. It does not appear to be carbon fiber reinforced. I have no skills that would allow me to do “ mods” to the kit for turbine use. I have read several threads that say you can, in fact, fly these without the mods if you keep the power to a 60 size turbine, and don’t fly at full throttle for extended time, or when turning the jet at speed. What do you guys think? I’ve had a couple before, and they were a nice , small jet I could haul in my Durango and not have to pull my trailer....good off my local grass field...my other jets are bigger, and composite. I would appreciate any feed back...
Old 09-11-2019, 07:54 AM
  #5000
mofosheee
Hello
I have a boat load of new parts; P60 turbine (used) , pneumatic landing gear, turbine mounts, airframe, wheels all for the Falcon that is looking for a good home. Thank you, Jerry
p.m. me if interested
