New ECU
1) Press and hold anywhere on the dashboard to get to the desktop
2) Press the Turbine icon
3) Press #3 for Restart
4) Use #1 or 2 button to select the three modes, Restart OFF, Restart ON and Glider
Barry,
The various engine settings quoted in the manual coming with all the new engines (ecu and gsu and pump) - are these settings only for the new engines or can we also use them with our Xicoy esu's?
What telemetry can we use with the new ecu's, or will the Xicoy adapters still work?
See you at BITW.
JanR
See you at BITW.
JanR
Barry,
See you at BITW.
JanR
See you at BITW.
JanR
See you soon!
Barry
Question for ECU in general but more spicificly the new ECU. If I connect the ECU battery to the ECU it will not turn on until I power up the receiver...right? And if so is it ok to leave the battery connected and can I charge the battery while it is connected but not on?
Thanks.
TB
Thanks.
TB
Thanks.
TB
Thanks.
TB
Had a friend scorch a model just last month for being lazy and doing this.
He could have burned down his house if the battery was hard to remove and maybe the plane contained some residual fuel...
Personally, my advice is: do yourself a favor and ignore your own question
My Feedback: (9)
Thanks.
TB
Thanks.
TB
I too am very interested in the telemetry adapter (Spektrum). I'm also interested in the software to download the data.
I know they are working on the manual but the data software and telemetry adapters are probably missed more (hint)
My K-45 runs perfect and the GSU is very cool
Can anyone tell me where the battery used information is stored and if and how it can be reset after a battery charge, talking about the new ECU here?
I am told it is in the 'info' menu but I cannot find it there.
This is a handy tool and I hope that it has been incorporated into the new ECU like it was in the Xicoy ECU.
Ron
Ron
Hello,
Now that the Manual is out for the G2 series engines I thought there would be some information on the Telemetry capabilities of the new ECU? Any target date on the advance features of the G2 series ECU?
http://www.kingtechturbines.com/doc/Manual_G2.pdf
Cheers!
Desert Fox 1
Cheers!
Desert Fox 1
My Feedback: (61)
i'm considering a new 120G2 for my 1/6.75 extreme jets f-16 and i have two questions. first i was rifling through you tube looking at some kingtech videos when i ran across a guy starting a turbine when the video showed his futaba transmitter briefly. it showed a full screen of turbine read out of the turbine parameters . anyone know anything about that? i have a 28x and i'd like to be able to watch the turbine parameters while starting up etc. also.... has there been ANY issues with the new ECU ? thanks,WB_1
My Feedback: (9)
Hello Ron.
On the older Xicoy ECU you could use full turbine telemetry. With the new Kingtech ECU the telemetry is not finished yet but its in the works for jeti JR and spektrum. Futaba will not have it at this time.
The new ECU/fuel pumps have been fantastic so far. I have done 2 installs at the flying field with them so far and both flew flawless. I would say probably the biggest problem has been people connecting the wire harness wrong lol. The plugs are labeled now so that problem should be gone.
My Feedback: (61)
Hello Dave.
