Glue for planking
Glue for planking
Been wondering what glue you guys use that dries quick but isn't a pain to clean up like CA when you plank a big plane. Titebond is nice, but takes too long to set up. What other glues are used?
I use both at the same time,, take a look here http://www.rcuniverse.com/forum/seap...l#post11447017
Is SIG bond different than PVA like Titebond? I get mixed messages on that. Does it set quickly?
My Feedback: (158)
Sig lists Sig Bond as an aliphatic resin. It's similar to Titebond and is easier to sand. It will bubble up when sanded so I sand perpendicular to the glue joints at first. I also use it to join the wing sheeting together. Try a few strips before you commit to it. Dan.
Titebond can do that too. I found that if you apply a little heat first, then it turns rubbery and easier to sand without marring. I tried the TB and CA approach and it worked well. Top of the fuse is planked, working on assembling the bottom then I can plank it.
Don't let the fact that titebond takes a long time to cure stop you from using it. What you need is a different build methodology. While a planked fuse is waiting to cure, set it aside and build on the wing, or the stab, or something else.
carl
carl
acdii,
I've planked a few models in my time.
Here's the latest and it's current, in fact I started prepping it for silk covering.
Believe it or not all I use is CA. I put a dab here and there on each applied plank. The fit is key.
Charles
Charles
Got the fuse planked, no different than doing a boat hull, only much bigger and easier. Could have used my proportional dividers to make it easier, and my ships curves, but they were put away.
Tom,
Nice work, nice finish!
I posted to be a member of the Brotherhood. Do I get a Brotherhood number?
I've been using a white primer out of an aerosol can.
This GBZ is planked.
Charles
Charles
For planking best to use Tightbond as it sands great ( CA does not ) and it is waterproof so not effected by moisture long term
I use CA to build everything i can as it speeds the build and will keep the plane together for the long haul
i use Sig dope to fuel proof what is required ( not epoxy)
i have planes that i built 20 years ago that still have good glue joints and I still fly
Enjoy
Enjoy
Tony,
I've never finished a model with dope. I stay away from it.
I only use it, sometimes, to fill grain, and to apply silk. I silk the entire model. Well, I have used glass cloth also and silkspan.
Lots of ways to get to that end result.
Charles
Charles
OH
I use old fashioned model airplane cement. Sigment, currently. It dries reasonably quickly and sands very well. I run a bead along the plank, use a drop of medium CA to hold it to the former at the beginning, then pin the strip about every two inches or so.
There's more than one way to skin a cat. I know, terrible expression..
I've never used anything but CA and I never used a single pin.
With CA, as I said, I use a dab here and there so sanding the thing round becomes easier.
I use .125" contest grade balsa only. Planks can vary but .25" or just a tad thinner is what I have found to work well.
I hand sand/bevel so each piece is tight.
CB
