Go Back  RCU Forums > RC Airplanes > Crash & Rebuild
Reload this Page >
bent and dented aluminum spinner
Crash & Rebuild Post your crash stories, pictures and if you want to document your rebuild you can do that here too!
Old 07-09-2020, 05:31 PM
tbone4343
Question bent and dented aluminum spinner
how do i remove a small dent in an aluminum spinner and small bends in the aluminum where the prop exits spinner . its not real bad but would like to straighten it out and polish it any help would be great .
Old 07-10-2020, 02:49 AM
ETpilot
ETpilot's Avatar
Think auto body repair. Where smooth faced dollies, spoons and a hammer are used to reshape dented metal. Place dolly on inside and tap tap tap to reshape. Just light taps at a time. Same technique could be used for bent areas. You will have to make the dolly or dollies. Super smooth as possible. Go slow.
For example I had an aluminum cylinder with a piston that had O’rings seals. The cylinder was dented during O’ring replacement. I used a pipe just smaller than the cylinder. Cleaned, smoothed and polished as best I could. Then with a rubber dead blow hammer I worked the dent out. May have used a regular hammer too. Can’t remember. Once done the cylinder worked again and leak free.
Good luck with your repair.
Old 07-10-2020, 03:07 AM
ETpilot
ETpilot's Avatar
Just remembered that Harbor Freight sells a watch makers hammer that may be good for this repair. Check it out. Then you just need the dolly.
SKU 99895
Old 08-21-2020, 06:42 PM
gdwrench
I like that item,.. I'd use a nice piece of hardwood for the dolly, Aluminum is quite soft and wood will help with not scratching the surface so much
Old 10-12-2020, 07:26 AM
i.RIDE_H0ndA
i.RIDE_H0ndA's Avatar
Just remember, less is more. Sometimes the metal stretches a bit at the dent so go easy.
