Trouble Locating Replacement Spinners
Model: https://www.towerhobbies.com/cgi-bin...?I=LXETVD&P=ML
Engine: https://www.towerhobbies.com/cgi-bin...?I=LXRPD2&P=ML
I'm having trouble locating a replacement spinner cone for my model. I don't want a spinner nut because that isn't what is supposed to be on this model. I'm curious when you guys need to replace a spinner cone, and not just anything will do. Where do you buy them from?
I have an ARF model that requires me to use a red 2 1/4 inch spinner. Of course the one they gave me is plastic. My starter burned a groove into the nose. A cold .75 OS Engine ABL engine turns over hard. The spinner needs to be completely flat on the back plate. Otherwise it will rub on the cowling. The Cowlings location can not be changed. The engine mount can not be changed. Changing either one of these things would make a mess of the cowling. Otherwise I would just buy a dubro spinner as a replacement. I'd be willing to switch to an aluminum nose cone if I could find one with a completely flat in the back. I never owned an aluminum one which is part of the reason why I'm asking about this. A flat back plate is key for proper spacing.
In the pictures I'm showing an extra spinner cone from a former Airplane. The one that is really damaged my dad put epoxy on it. He wants to experiment. That is the 4th picture.
Distance between Cowling and Spinner Cone
Trying to Epoxy the groove.
The difference between the back plate I need and Dubro's back plate.
The manufacture is a little iffy. Because you got to go here Spinner ( Plastic Plate ) | Accessories | Phoenixmodel.com | Phoenixmodel | Aircraft model Manufacturer but buy from here: https://zigirc.com/ Back in 2018 did this research and they told me that plastic spinner cone will be 20 dollars and I must use paypal.
Here is a list of websites that I found that have spinners. I'm providing you these links so that you can see I've been doing some research.
https://www.dubro.com/products/spinner-2-blade
https://www.towerhobbies.com/cgi-bin...EARCH=spinners
https://www.horizonhobby.com/categor...ories/spinners
https://www.motionrc.com/collections/spinners
https://www.gravesrc.com/radio-contr...pters-etc.html
https://www.f3aunlimited.com/airplan...ories/spinners
https://www.chiefaircraft.com/radio-...-spinners.html
https://www.theworldmodels.com/store...t=44&sub_id=28
The Great Planes GPMQ4766 is plastic red spinner and a completely flush aluminum backplate and is available from Graves RC. Their website was one that you listed.
Just a word of advice, do NOT run your engine with the repaired spinner !
Good luck
Good luck
Is this the correct one?
truturn.com
https://www.truturn.com/
Or is it this one?
tru-turn.net
Products - Tru Turn Spinners
Or is it this one?
https://www.centralhobbies.com/cat3....t=13&subcat=88
Or is it this one?
https://www.chiefaircraft.com/radio-.../tru-turn.html
Or this one?
https://www.propshophobbies.com/sear...show=90&page=1
I've only come to trust, Amazon and Towerhobbies for Modelling Equipment. I know that there are others out there but if I'm not careful I might come across a phishing website.
My Feedback: (8)
truturn.com is legit. So are Central Hobbies and Chief Aircraft. Your best bet is to call Truturn. They are very knowledgeable, helpful, and will get you fixed up with exactly what you need. The first picture is the nasty white plastic spinners that were on a Twin Otter I got in a trade. First thing I did was replace them with the TruTurns in the second picture. Besides the improvement in fit and appearance, these are ultra smooth and vibration free. Best spinners on the market.
It seems that the consensuses is that aluminium spinners are the best. I do need to say that the spinner on my Zlin 526 is a great planes plastic spinner and it's 10 years old. It is scuffed up because sometimes the starter slipped on it too. It seems that the spinner on the Ryan is worse because it's very pointy. I'm pretty sure that if I switch to an aluminium spinner I will need to rebalance the model - Add more weight in the tail.
