Questions related to twins
Hello,
Ill appreciate info about topics related to twins.
1. In a big planed twin project, powered by 2 DA85, how can I keep the platform relatively straight flight if one of the engines fail? Adding to the implemented rudder angles I thought using a gyro for rudders.
2. Is it posible to change rotation direction in a DA 85?
Avi
Avi
My Feedback: (20)
AVI,
I reversed the rotation of a DLE 35 and the method should work on any reed valve engine. If the Hall effect sensor is placed on the engine so that it is the same number of degrees after top dead center as the factory sensor is before top dead center the ignition will be timed for the engine to run in reverse. The reed valve doesn't know which way the engine is turning. Rather than try to drill new mounting holes for the sensor, I purchased an aftermarket Hall effect sensor that attaches to the crankcase with a worm drive clamp. I also made a small fixture to help accurately locate the new sensor.
One major drawback to this is that a pusher propellor is required and they are very hard to acquire.
I son't have any experience with gyros on my twins, so can't comment on that.
Chuck
Chuck
My Feedback: (54)
DA engines
Avi,
Desert Aircraft is great with customer service. They may even do the mods for you for free. They normally only charge for parts.
A gyro may help on takeoff if it is on “Attitude Hold”, but in normal cruise flight, regular gyro setting is better. Attitude Hold wants to fly the plane in the last “attitude”, and doesn’t want to turn. Let’s say you want to turn left in the pattern. Giving left aileron for the turn, the rudder still wants to hold heading. So, you end up with cross control. Which on a single engine is a disaster. Putting a mix of aileron to rudder might help, but I am not sure.
You would be better off having a sensor that detects engine loss and reduces the good engine to idle and treating it as a dead stick. Most wreck their plane when trying to fly it out on takeoff. Loss of engine in cruise is easier for the one landing approach. Trying to do a go around is always a mistake. Watch YouTube.
Thank you both, Chuck and RCflyerDan.
I was thinking of using the gyro someway slaved to the RPM from both engines to be triggered only if one engine down.
Avi
Avi
Avi
Avi
My Feedback: (54)
I’m sure others will chime in too.
My Feedback: (20)
Avi,
What is the model you are planning to build? If it is to be scale I would align engines the same as the full-size for appearance sake. I have built several twins, although no where near as big as you are planning, and have always set the engines straight ahead.
As the carnival barker says: "You pay your money, and you take your chances."
Chuck
Chuck
Avi,
I would strongly recommend a twin sync. Read up on the benefits. And the downside.
https://www.bigplanes.nl/contents/en...chronizer.html
Avi
