Electrifly Triton EQ Error codes
Hi Guys,
I have the Electrifly Triton EQ. I got an error code - " Battery Exceeds Time Limit" Anyone know exactly what's going on here, other than the obvious? I am guessing something to do with the Amp setting for the charge rate.
thanks
Ed
thanks
Ed
The charger has reached the safety time limit ,displayed the error and shut down. This happens typically when charging high capacity Nixx packs at a very low amp rate. The timer can be turned off if charging Nixx packs this way.
It can also go off if a Lipo pack with a bad cell is being charged and is taking a very long time to balance. In this case you should not turn off the timer.
Is it possible that I am also just trying to charge the packs at a two low of a charge rate? If I was to raise the rate, that would charge the battery faster, correct? Then maybe it would charge the cells within the Time frame? I think I tend to set the charge rate charge a little on the low side, as to not overheat or burn up a flight pack.
Ed
Ed,
Yes, the amp rate is the charge rate. Charging Nixx packs at a lower rate is always better for the pack but it does take longer to charge. I never exceed a 1C charge rate and always try and go lower for both Nixx and Lixx packs.
For example; a 2000mah NiMh pack would be charged at a max amp setting of 2amps; 2amps = 1C charge rate. Typically though a 1amp setting is better for the pack; 1amp=1/2C charge rate.
For a brand new pack a forming charge should be used for the first time at 0.2amp or 1/10C charge rate.
