Topflite Giant scale Cessna 310
Beautiful Giant scale Cessna 310. Military markings. Excellent electric conversion. Flies on 2 6s 5000 batteries. Some very minor cosmetic paint issues (will provide more photos, information if seriously interested). Robart air retracts (work perfect. no leaks.) RTF Just install batteries, bind to Spectrum radio and fly! (flight pack is a Li-ion) - included. Flys like a trainer on steroids. Local pickup only please. I will meet buyer within reasonable distance.
FYI: I have one of these and have about 25 flights on my, and this is about my:
Top Flight Cessna 310 (ARF)
Wing Span: 81"
Weight: 21 1/2 lbs.
Radio: Spektrum DX7 and AR7000 Rec.
Prop: (2) 2 Blade 13 x 8 APC Electric Prop
X-tra's: Has a lighting system, covered in monocoat, fiberglass fuselage, built-up wings, (4) aluminum wing joiners
Engines: (2) Great Planes .60 Rimfire Brushless electric out runners motors
Specs: RPM/V (kV rating); 650
Input Voltage: 18.5-22.2V (5-6S)
Burst Watts: 2200
Max. Constant Current: 65A
Max. Surge Current: 85A
Max. Constant Watts: 1683 W
No Load Current: 3A
ESC's: (2) Great Planes Silver Series SS80 Amp
Specs: Input voltage: 14-32 NiCad/MH cells, 4-12 LiPo cells (12.4-50V)
BEC: No BEC Circuit, opto-isolated
Output Current: 80 A continuous max, 96A surge max
Max. Output Power: 4000 watts
ON-Resistance: 0.002 ohms
Thermal Cutoff: 230 deg. F (110 deg. C)
Dimensions: 2.4 x 2.36 x 0.7 inches (60 x 67 x 18 mm)
Weight: 5.1 oz (145g w/deans ultr-plug, rx plug, 3 6mm bullets)
Wing Area: 951 sq. in.
Wing Loading: 40 to 55 oz/ft.
Batteries: (2) 1 for the servo's and 1 for the lighting system, 1500 mah, 4.8 volts
Batteries : (2) Thunder Power RC Elite, 5000 mah, 6S, 22.2 volts, 55C
Specs: Max. Charge: 8C
Max. Cont. Discharge: 55C
Max. Burst Discharge: 100C
Max. Charge Current: 40A
Max. cont. Current: 275A
Max. Burst Current: 550A
Weight: (grams) 782
Dimensions: (h x w x L) (mm): 47 x 46 x 154
Prop Meter Information:
(A) Amps: 73.30
(V) Volts: 21.86
(W) Watts: 1550.0
(AH) Amp Hours: 0.876
(WH) Watt Hours: 7.6
(PW) Peak Watts: 1667.2
(MV) Min Volts: 21.65
(PA) Peak Amps: 74.35
Ground Thrust Pull: 17 lbs
Wing Span: 81"
Weight: 21 1/2 lbs.
Burst Watts: 2200
No Load Current: 3A
Weight: (grams) 782
(A) Amps: 73.30
(V) Volts: 21.86
(W) Watts: 1550.0
