Instant Throttle Response
My Feedback: (8)
All of my turbines are Jetcat and they are older ones. I have a plane where I need a throttle response that is virtually instant. Do any of the current Jetcat turbines have an extremely fast throttle response?
I would really like to stay with Jetcat but if I must, I am open to switching in order to get the response I need. Not really considering Jet Central or Kingtech but info on others would be useful. I tried out an Evojet 220 at Kentucky Jets and it had a very impressive throttle response.
This will be a replacement for an original Titan (excruciatingly slow response!) in my AD Scorpion.
My Feedback: (38)
You are leaving a lot of reliability, response, and performance on the table by not considering Kingtech, MY 210 comes on like a freight train, and very quickly, My K-170 is also extremely fast on spool up,, If you are off idle they are both just a couple seconds till wide open. You state you want instant throttle response, If you mean you want to floor the left stick and have a turbine that goes to WOT instantly, that's not going to happen, its just a matter of how long it takes to spool up and get flying again.. I also have a Merlin 160, It too spools very fast.
Personally, I would say if you put a K-160 in that scorpion, it would be a beast,,
As far as jetcats Go, I have had a p-70, p-80, p120, and a p120sx,, none of those turbines spooled up even remotely close to what I have now, The p-70 and 120 took FOREVER,, however, none of mine were the newest models either,
My Feedback: (8)
"You state you want instant throttle response, If you mean you want to floor the left stick and have a turbine that goes to WOT instantly, that's not going to happen, its just a matter of how long it takes to spool up and get flying again.."
Yes, I am well aware of that.
My Jetcats are quick. There are menu items that allow you to adjust the Throttle response from idle and the throttle response from essentially mid-throttle. I actually have the idle response set to Very Fast and the mid throttle response set to normal. The mid throttle response comes on a little too quick in the fast setting, at least for me.
There is another way of improving midrange throttle response/ sensitivity....use the throttle curve function in your radio and elevate the midpoints on the curve so you create a more linear feel with thrust. This very much improved the feel on the low end and midrange of the throttle on an old 120 I have in an f18 which is often where the turbine feels laggy.
just a thought that does not cost a cent. ....give it a try. You might be pleasantly surprised.
NY
Steve, I am flying the 220 Jet Cat RXIB and its very fast on acceleration. The new brushless pump makes a big difference. The starter is also brushless and turns the shaft by magnetic drive. The magnetic drive also allows the starter to become a generator to charge the ecu battery and the flight packs. I never have flown the evojet so I can not compare. I have owned\ran ever other jet cat and the 220 is a big step above past engines. I also agree with Craig, that putting a throttle curve in the radio is a big help.
My Feedback: (51)
maximum acceleration speed is defined by the engine's mechanics, not the pump delivering fuel.
Brushes pumps can accel really fast too, its the ECU thats holding them back and spooling slowly - on purpose, in order not to exceed the top engine acceleration speed and cause a stall / fire.
NY
So your saying that because a brushless pump is faster to respond to commands of the ecu and your able to better control an over shoot of rpm that it makes no difference in the ability to spool? While I agree that the mechanical design has a lot to do with how fast and engine can ramp up the limiting factor in a JetCat ECU is temps, so if the pump has nothing to do with it must be a better design of the compressor, combustion chamber , and EGV because the new 220 runs it butt off and to me the acceleration is greatly improved over early generation JetCats and that's what OP wanted to know.
My Feedback: (8)
Been doing a lot of research on engines since the first post. I found a video on Youtube of a guy playing with the throttle on his Jets Munt Merlin M140XBL. The throttle response was impressive and just what I am looking for. So, this engine is likely the replacement for the old JC Titan in my AD Scorpion. Has both the pump and starter brushless motors.
My Feedback: (57)
Before I call on the BS flag.....ECU nor Pump makes the spool up faster, it is just an "illusion". Bottom line is engine design. How is it done? by having a turbine design that can dissipate the energy boost created in the combustor faster, more efficiently. And because our engines are single stage, a compressor that is capable of feeding fresh air into the combustor at the same rate.
I do tend to believe that our hobby engines are not "designed" for performance, but rather simplicity to keep them affordable. Someone with CAD knowledge rough drafts a turbine, machines it, test it, then tweaks it here and there to make performance improvements (which is perfectly allowable for our hobby use). And this practice seems to be dominated by KingTech lately. Whatever they are doing, they are doing good.
David
David
My Feedback: (30)
My KT 140 with diesel was nearly or just as fast as a big fan with medium heli spool... I couldn't tell the difference.
Slow spool was one of my pet peeves about turbines and diesel with the KT-140 took care of that
