Byron F15c Project >
Byron F15c Project
Byron F15c Project
Old 04-13-2020, 06:18 AM
  #176
Pull Up Now!'s Avatar
I have more updates on this project if anyone is still following this thread. Not going to bother if there's no activity.
Old 04-13-2020, 06:39 AM
  #177
My Feedback: (40)
Since I have one of these sitting in the garage I have been watching, silently ......
Jim
Old 04-13-2020, 06:52 AM
  #178
jcterrettaz's Avatar
always interesting , following
Old 04-13-2020, 07:24 AM
  #179
My Feedback: (35)
frankle951's Avatar
Always, my old jet.
Old 04-13-2020, 12:07 PM
  #180
RickP's Avatar
Following, Love the Byrons. I always thought a old Byron kit is still cheaper then a new turbine kit and would make a great retrofit project. Please update us....
RP
Old 04-13-2020, 04:46 PM
  #181
RP
ok, gathering some pics right now.
Old 04-13-2020, 04:59 PM
  #182
My Feedback: (20)
Viper1GJ's Avatar
Following, keep posting, thanks!
Old 04-13-2020, 06:59 PM
  #183
I finished reinforcing the elevators with a heavy rib, covered over with carbon fiber. Also installed a tool steel hardened pivot rod.
Used construction paper to piece together the profile for the landing gear support formers.
Took a pic of the paper former, imported it into Solidworks, scaled it, and designed the actual cad gear support parts.
3D printed the formers to do a final fit check before actually machining the formers.
Everything in place, gears work, fit is good with a few design changes.
View from underneath of the left main gear.
Put the plane on it's back legs and use the stance to design the nose gear supports. I want a tiny negative AOA as it sits on the ground. I will probably have to cut down the strut a little.
Old 04-16-2020, 03:29 PM
  #184
My Feedback: (35)
frankle951's Avatar
Nice work on the retracts !!!
Old 11-14-2020, 07:15 AM
  #185
It's been a while since I worked on the F15. I was completing a TopRC Hawker Hunter. I love the look of those early jets. Anyway, I finally got the aluminum formers (of my own design) back from the CNC shop and they are beautiful and fit great. I may add some lightning holes in them, and some glue grooves around the outside edges. I'll have to think if that is needed. Anyway, this structure, which includes new 5/8 dia second-spar tubes, now forms a complete load bearing backbone for the whole jet. I'll be committing to these by gluing them in soon. No going back after that.
jescardin (11-14-2020)
Old 11-14-2020, 07:21 AM
  #186
My Feedback: (35)
frankle951's Avatar
Wow, that really look good and strong, you are like me, I stop working on my F-16 and started working on a new DV8R and a used DV8R, the used one is up and flying, new one just need a turbine, good to see you back on the F-15, I will be watching for more build.
Old 11-14-2020, 08:10 AM
  #187
Just for the record, before anyone notices, the retracts are each on the wrong side. The wheels go towards the outside! UPDATE: I fixed it. There are two more tasks before actually gluing these formers into the fuse. First, I need to make the actual flight gear mounting beams. The ones in the picture are still the PLA 3D printed ones. The 5/8" square stock was ordered, and should arrive today. The second task is to machine a tubular spar that will span all the way from the left set of formers to the right set. This will help align the left and right halves while the glue is drying. Later, I'll cut this one long spar in half and they will become the flight spars.
Old 11-14-2020, 09:54 AM
  #188
N
Now turning the spar!
Old 11-14-2020, 11:03 AM
  #189
A
And with the “double length” alignment spar in place. The length is calculated to be exactly the right length for each side when cut in half.
paulhat (11-15-2020)
Old 11-18-2020, 08:00 PM
  #190
The entire gear assembly is now permanently installed in the Byron F15C fuselage. This was a big, long term project, but now it's on to the next task. Fuel tanks. I'd like them as far aft as possible, which will mean a complex custom shape. Probably some CAD work and foam cutting involved. Here's a video of the main gears installed, and working.
Old 12-01-2020, 06:09 PM
  #191
I'm pretty much done with the Byron F15C gear installation now. That was a months-long journey. Thanks to Zach Geragi for the excellent CNC machining of my Solidworks design. We have collaborated on a number of projects, including Bob Moore's giant Cessna Citation landing gear, and the Minnesota Giant B1 Lancer model. That last one is huge, it has an 18ft wingspan. We also developed a retrofit servo-operated nose gear steering kit that replaces the troublesome hydraulic steering in the Fly Eagle Jet and Skymaster F16's.
Now, I'm working on some custom fuel tanks. It's a challenge to take advantage of the irregular shaped voids close to the jet's CG in a gas tank design. I designed the tanks, and 3D printed them to make sure they fit. You can see them in the pictures. I actually managed to fill up the wing fillet cavities with "tank". Now that the tanks have been fine tuned a couple times, I'm experimenting with making one-time molds off the 3D printer. The tanks are mirror image models of each other. The first design was great, but the first installed tank blocked the second tank from fitting in, so that was the first big design change. That change made the volume too small, so I had to expand the tanks in other areas. Then the retracted mains interfered, so on to the third iteration, which worked. Now I'm printing the first of the mold pieces. The printed mold are one-time use, and I can break them apart to remove the tank pieces.
Old 12-01-2020, 09:25 PM
  #192
My Feedback: (34)
Great work! How many oz do your tanks hold? I put 2 Dubro 80oz tanks in line as far forward between intakes as possible.
Where you get your pipe? Mine came with a Y pipe but it has 4 small holes next to center splitter
Old 12-01-2020, 10:22 PM
  #193
Each tank is 220 ounces totalling 440 ounces, which gives about a 9 minute flight at full throttle. But of course I don't fly at full throttle during a flight so I'll land with about 20% left over, maybe enough for one go-around. The Y-pipe came out of a FeiBao F15E and it fit very well. Of course I had to completely redo the original formers to accept the Y-pipe. I really looked over the split carefully on my pipe. There is a stainless steel double piece over that area, but no holes. Have those holes been a problem?
Old 12-01-2020, 11:27 PM
  #194
Hi Pull up now
I also made a tailored fuel tank for my Yellow F-16. I 3d printed negative moulds. 2 halves, one with a seam to connect easily.
My surface treatment was like this:
Sand 240 paper
Spray filler, do not spare, make 3 thick layers, then let it dry for 48 hours.
Then wet sand 600 paper, let it dry again. Then I waxed with Partall hi temp wax, 2 times.
Ready to laminate.
Old 12-02-2020, 05:00 AM
  #195
Cetigershark, that's good news you were able to make a printed negative mold. My tank is so odd-shaped that there is no clear parting line and no draft to pop the tank out of the molds. My plan was to destroy the molds to leave the parts, and glue the halves together and wrap the seams later. How many glass layers, and what ounce glass? I was thinking 3 layers of 3 ounce glass, but I've never done this so what's your advise? Here's a pic of the first mold piece. It barely fit on my printer table.
Old 12-02-2020, 05:47 AM
  #196
I used 3 ounce glass cloth, I would say 3 layers. Laminating Resin was from R&G Germany. In the corners I put extra triangle cuts of glass to reinforce them. After curing, I applied a light coat of resin with lots of microballons to the inside, just to be sure everything is sealed. Then I unplugged the halves and glued them together after having installed the fuel lines. It clearly wants to implode under vacuum, so it is totally sealed/airtight.
Make sure:
Resin is kerosene proof
corners/edges are a bit reinforced
your last coat to the mould withstands wax/parting agents... I have used 1K filler, and it was not dissolved by the wax. Actually surprising, but I am glad it worked out like that.
Old 12-02-2020, 07:48 AM
  #197
My Feedback: (35)
frankle951's Avatar
Default Byron f15
Sweet progress, it's going to be a great flying F-15, thanks for posting.
Old 12-30-2020, 04:27 PM
  #198
I have been following this thread with much interest. I have a Byron F-15 new in box that I purchased about 20 years ago. I have always wanted to install twin 80's in it whenever I got around to building it. Keep the posts coming!!!
mikes68charger (12-31-2020)
Old 02-06-2021, 05:57 PM
  #199
Default byron f15
This is the stock Byron elevator support, I made a 1/8 former, I did drill 2 big lightning holes, this peace of ply boxes off the one side of wood for inside attachment, this also has glue to all there sides of fuse in this area providing a lot of strength.
I know some worry about such small elevator tubes, but as these tubes are nothing more than a pivot vs most others where this tube is a pivot and provides rotation forces. Using the stock Byron elevator servo arm for movement gives it 2 points of support,
I do got a sold peace of carbonfiber on order to fit in current elevator rod, I did this on my Byron F16 I converted with JetCat P120SX and never had issues
hiya I'm in search of a set of byron f15 flying services do you know anyone who wants to sell some
frankle951 (02-06-2021)
Old 02-09-2021, 11:44 AM
  #200
My Feedback: (9)
Airman98's Avatar
Hello, A friend of mine told me about this thread and I thought I would share the build Im doing on my byron F15. I'll be installing 2 turbines, haven't decided yet on the size. There will be no hatch on the top only two small ones on the bottom to access the Turbines. For the horizontal stab I ordered the mechanism from fabeo that they use on their F15. The stab now plugs in and is bolted down. The pivot point is much different than what byron had.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
