CARF REBEL 2m
#753
It looks like the pipe itself is projecting way inside the bell mouth rather than the bell being mounted on the end of the pipe. Are you sure that’s the way Grumania intend it to be mounted?
Doesn’t look correct, no way for entrained air to enter the pipe.
Malcolm
Malcolm
#755
Here is the installation pic from the Grumania site. As you can see the pipe terminates at the entrance to the bell.
Sorry to labour the point but don’t want you to have problems when you go to fly!
Malcolm
Malcolm
grolleman (10-07-2023)
#756
Thank you for thinking along, so we can help each other.
Installed it exactly like this.
The turbine exhaust is no longer unfortunatelyUnfortunately, I also had to buy another pipe, the original one didn't suit me as it was shorter.
As a result, the turbine could not be secured
#758
The one picture is a little deceiving as the strap of the engine looks like the end of the pipe. It’s just an optical illusion, thinking that the strap is the inside pipe.
#759
Flew the Rebel 2M today for First Time, Flew Great one click down elevator. What is the best Crow setup for flaps, I landed mid flaps with no crow pretty twictchy but OK.So what does most people add to the Flaps and how much for mid Flaps and Full Flaps. Do you add Elevator or Ailerons to the Flaps??
#760
None of our 12+ models use CROW…but landing with ‘lift’ flap is something I would never do! Full flap and it’s great, down elevator is needed with both flap positions.
It will depend how much flap you have set, on how much down, but 1mm take off and 3mm landing measured at root would be a start.
DenisFerrari (10-14-2023)
#761
OK,Thanks Dave So I have my Flaps set about like some of the Pictures you have posted of some of your customers Planes, so when the Flaps go down, I need to add down Elevator to that, On another note after I landed we noticed a little drip under the Jetcat filter, tightened up cap just like I read in one of your other post and no more drip.
All makes Sense
Thanks Dave
All makes Sense
Thanks Dave
#763
Dave W. The Down Elevator with the Flaps worked great yesterday, Glad I asked about Flaps Crow ETC. One last question???? I am Flying mostly off asphalt and I have herd you guys Talk about the Idle thrust of Turbine ? Mine seems to Idle pretty high, Can I idle that down some and what's a good RPM or setting for that???
#764
Great.
unfortunately nothing you can really do. It’s in the design of the turbine, the better manufacturers spend hours and hours getting a low idle thrust and good acceleration. Some turbines are double and even triple the best brands.
I find customers only look at the stated power. I look at the power, where the power is developed in the rpm range and idle thrust.
All you can do is add drag with more flap. 85 degrees is possible
Dave
Dave
DenisFerrari (10-26-2023)
#765
Is it going too fast on the asphalt during taxi ?
You could apply a little brake to drag it and also have some brakes on when landing.
#766
Well, I wasn’t sure if you could take a couple thousand RPM off idle speed but I sorta figured it would affect other areas of turbine acceleration etc. When I start it and taxi on asphalt it starts rolling pretty good till I tap the breaks? It just seems a little higher than my other jets?
#767
So what engine is this?
#768
Amusingly it’s a JC130Rx by the look of it. OK it’s over 150N actual, but all the ones around me with JP gear don’t roll on tarmac and land super slow.
There is usually some resistance on JP brakes, Electron I can see being free running.
DenisFerrari (10-27-2023)
#769
yes, its the Jetcat 130 it lands really nice and as slow as I want, best flying Jet I have, I just wasn't sure if people turned the idle speed of Turbine down some or not, I will just use brake a little more, it has the JP retracts,Brakes.
#770
Smoke tank ... and ... Installation of the smoke tube
Hello guys,
I actually wanted to use the CM-Jets tank with 3 liters of kero and 1 liter of smoke. But after seeing what this part costs me until I have it on the workbench here in Germany... no. That's why I'd like to see your ideas and installations.
Another question is, do you inject the smoke oil directly behind the turbine, i.e. into the thrust pipe or at the end of the thrust pipe, essentially into the open?
Thank you for your answers
Holger
Hello guys,
Holger
#773
I’ve had great luck ordering directly from Adrian at Electron in Spain, usually get delivery in less than a week. Jag RC is also good to work with, but they usually don’t have stock of what I’m looking for so delivery times are much longer.
#774
120 or 140 Turbine
Thanks guys for the Electron advice!
I just took delivery of my orange infinity classic. It's my first composite plane and I'm extremely impressed with the quality! I'm going with a Swiwin turbine because I live close to Bad Boyz, but can't decide between a 120 or 140. My focus is aerobatics, not all out speed. The price difference between the two is not that much. The weight and size are about the same. I don't know if the 120 would have a little less residual thrust at idle for landing and maybe the 140 would be nice for extra thrust if desired. I'm open to suggestions from your experience with this jet.
#775
I have flown them with both a120 and a 140. The 120 is more than adequate if you keep the over all weight down to around 27lbs, which is not hard to do with this jet. I prefer the 140 because I like a little more thrust authority. Landing is about the same with either.
if you are operating from thick grass the 140 might be preferable.
