Reload this Page >
CARF REBEL 2m
CARF REBEL 2m
Old 04-07-2020, 09:11 PM
  #76
Dave Wilshere
Originally Posted by A7Bldr
Dave, I'd consider opening up one or 2 of the black squares on the fuse side ahead of the inlets (the black trim scheme) and also look at adding a NACA duct on the bottom.
I'd run a bell-mouth and no intake ducting (or perhaps very short ones from each side).
I don't know how much intake area there already is, so I don't know how much extra area is needed; (do you have one to measure?)
These are just some
ideas and may not be feasible.
I have the CARF Viperjet and marvel at the lightness and strength. Gotta be an EDF option on this one, somehow....
Jim
Jim
I’m sure Daniel gives an inlet area on his website, on the CARF Hawk I was worried it would be a little on the small size so I opened up all the ducts, put slots in the inlet splitters, knew the nose doors were open at take off etc. I’m sure you can find away if you want it EDF. With the inlet duct fitted to the fan it smooths out any air just before it gets to the fan
Old 04-12-2020, 06:17 PM
  #77
Desertlakesflying
My Feedback: (28)
Anyone using CMJets smoke tank in the Carf version? Does it get in the way of installing the wing bolts?
Old 04-12-2020, 07:27 PM
  #78
bodywerks
bodywerks's Avatar
Originally Posted by cmjets
CMJETS tanks in Carf version
thanks to Marcelo and Thomaz Assis for the pictures.
BR from Spain
Carlos
CMJETS.com
Based on these pics, I can't see how it wouldn't interfere. You'd have to make it removable somehow...My Pro will have smoke, but my classic will be KISS.
Old 04-13-2020, 07:46 AM
  #79
Desertlakesflying
My Feedback: (28)
Looks like it will be in the way of putting in the wing bolts from those pictures.
Old 04-13-2020, 07:58 AM
  #80
skunkwurk
My Feedback: (18)
skunkwurk's Avatar
I have CM Jets tanks in mine, but I have the Pirotti version. When I was putting it together I planned to install smoke from the beginning. So, I deliberately made the wing bolts accessible from the wheel well. I added a ply block to the tank side/inside and hysol'd blind nuts. It's simple and quick to do.
Old 04-13-2020, 08:01 AM
  #81
cmjets
cmjets's Avatar
Them, how is the screw and nut wings installed ??
someone can show pictures ???
thanks in advance
Carlos
Old 04-13-2020, 07:49 PM
  #82
bodywerks
bodywerks's Avatar
thanks in advance
Carlos
This is a pic directly off the CARF sight. It appears that they do not attach the wings the same way as the rebel HOT, as the blind nut is in the fuse and not the wing, and the wing bolts are installed in the wheel well, so the smoke tank location shouldn't be an issue.
paulhat (04-14-2020)
Old 04-13-2020, 10:49 PM
  #83
cmjets
cmjets's Avatar
Them, is like original Pirotti planes. The screw entry throw the landing hole.
thanks
Carlos
CMJETS.com
Old 04-14-2020, 12:26 AM
  #84
bodywerks
bodywerks's Avatar
Yes. On my Rebel HOT, it enters through the fuselage.
Old 04-14-2020, 03:34 AM
  #85
Dansy
My Feedback: (53)
Dansy's Avatar
On the Pro it’s from the fuselage....front and back..
Old 04-14-2020, 02:17 PM
  #86
bodywerks
bodywerks's Avatar
is your Pro a CARF version?
Old 04-14-2020, 04:42 PM
  #87
Dansy
My Feedback: (53)
Dansy's Avatar
‘Not mine i just do the assembly......yes a CARF was in the very last container, just received last week and starting the build probably tomorrow....
bodywerks (04-14-2020)
Old 04-14-2020, 05:59 PM
  #88
bodywerks
bodywerks's Avatar
Nice! Ray said there are only a couple in the states currently. Mine's in the current container along with my classic. I was going to start a thread to discuss the quality improvements/ assembly differences over the Pirotti. You're welcome to beat me to it.
Old 04-14-2020, 10:06 PM
  #89
Desertlakesflying
My Feedback: (28)
From the inside on mine. Looks like its time for a new tank design.
Old 04-14-2020, 11:23 PM
  #90
bodywerks
bodywerks's Avatar
I definitely prefer bolts in the fuse like this. But it definitely makes for problems having a smoke tank there.
Old 04-15-2020, 05:25 AM
  #91
Dansy
My Feedback: (53)
Dansy's Avatar
I never build a Pirotti RP so I won’t be doing that.....and that would be of little use anyway, this is CARF and it shows....lots of differences some seem good some seem CARF Lol.....
bodywerks (04-15-2020)
Old 05-09-2020, 12:46 AM
  #92
jamessymons
Some pictures of mine. Must say the quality is pretty spectacular. CARF have done a good job.
The following 5 users liked this post by jamessymons:
bodywerks (05-09-2020), camss69 (06-20-2020), Desertlakesflying (05-11-2020), Kenrico (05-09-2020), paulhat (05-09-2020)
Old 05-11-2020, 02:46 PM
  #93
Desertlakesflying
My Feedback: (28)
You'll love it!
Old 05-17-2020, 01:40 AM
  #94
jamessymons
Busy planning the install.
paulhat (05-17-2020)
Old 05-17-2020, 10:34 AM
  #95
Desertlakesflying
My Feedback: (28)
I thought about doing this too at first, but then decided against it with the tank being a normal squeeze seal and bolt in. Figured I wouldn't be able to see any leaks or bolts coming loose if I did. I just made a lip long enough for a few things, but not too far.
Old 05-18-2020, 05:04 AM
  #96
bodywerks
bodywerks's Avatar
Comp-ARF did a wonderful job on my two custom scheme Rebels, one a classic, the other a Pro. I will probably start on the Pro first because I already have servos for it
The following 2 users liked this post by bodywerks:
Desertlakesflying (05-18-2020), paulhat (05-18-2020)
Old 05-18-2020, 05:33 AM
  #97
jamessymons
Love the color scheme !
bodywerks (05-18-2020)
Old 05-19-2020, 12:02 AM
  #98
jamessymons
Does anybody think i will have a an issue putting in a larger (2.9l) fuel tank ?
James
Old 05-19-2020, 02:17 AM
  #99
bodywerks
bodywerks's Avatar
That's not larger, that's smaller!!!
Stock tank is 3.6 liters. If you meant 3.9L instead of 2.9L, then no, no issue. In fact CMjets sells a 4L kevlar tank for it:
https://cmjets.com/pirotti-models/57-rebel-4l.html
Old 05-19-2020, 08:58 AM
  #100
jamessymons
Bodywerks, you are absolutely correct. I got my wires crossed between the Classic and Hot lol.
