Reload this Page >
T-One Models F22 Raptor build thread
Old 12-22-2020, 10:26 AM
  #251
gunradd
My Feedback: (9)
gunradd's Avatar
Originally Posted by FenderBean
I received these same pictures over a week ago when you friend received them. He mentioned having to pay for them, is the factory going to charge for new rudders for the current customers?
i am not sure Keith. That would be Dirk and T-1 to decide.
Old 12-22-2020, 06:25 PM
  #252
cycross
cycross's Avatar
Just throwing up an idea from the F3F glider community. We have used LDS (Linear Drive System) for a long time now for both flaps and ailerons with good effect (big surfaces and big throw is not an issue; single-side-hinged flaps can deploy to 90deg) and the design can be leveraged IMO. There is no need to go this slim as the original design is meant for glider thin wings, and the rudder bulging pocket could be put to good use to disguise the linkage.
LDS example
Old 12-23-2020, 05:31 AM
  #253
gunradd
My Feedback: (9)
gunradd's Avatar
The issue with the LDS system is torque. I used a similar set up on my F15 rudders I built. It worked on the aircraft since it has tiny rudders with low stress on them. I tried to use it on the ailerons on my F15 and ended up not going that route due to torque. You would need a to have offset hinges on the rudder to increase the torque on the F22 using this system so that's a no go. Still a good idea though and thanks! We need out of the box thinking to solve this and keep it hidden.
Old 01-23-2021, 07:26 AM
  #254
gunradd
My Feedback: (9)
gunradd's Avatar
Some good video a guy did from my club.
The following 2 users liked this post by gunradd:
patf (01-23-2021), Sparhawk (01-24-2021)
Old 03-22-2021, 06:22 PM
  #255
gunradd
My Feedback: (9)
gunradd's Avatar
Pics from FLjets!
super strong crosswind all week. She handled it well.
I had zero issues with the plane. Nothing broke and flew it allot. Kingtech 260 was flawless. ARsmooth flight helped out with the very strong crosswind.
video of crossword nd flight and landing.
jescardin (03-22-2021)
Old 03-22-2021, 06:42 PM
  #256
sysiek
My Feedback: (176)
sysiek's Avatar
Hey buddy your f-22 looks awesome definitely one of his kind and definitely the best looking probably in the universe A+++++++ .
Old 03-23-2021, 06:33 AM
  #257
David Jackson
My Feedback: (15)
Hey Gun,
That F-22 looks great. May be one day, I'll get mine in the air. Hope to see yours fly at Kentucky Jets this year.
Old 03-25-2021, 11:13 AM
  #258
DelGatoGrande
My Feedback: (23)
DelGatoGrande's Avatar
Originally Posted by DelGatoGrande
...its getting better !
Switches close up , everything is scale down to the marking details
more
cptnassos (03-25-2021)
Old 03-25-2021, 01:12 PM
  #259
ravill
ravill's Avatar
Gunradd, those pics are so friggin amazing!!!
DelGato! Those cockpits look amazing too!! Wow!
Old 03-25-2021, 02:06 PM
  #260
jvaliensi
Hi.
The IDS or LDS system use in gliders does not reduce torque. The arm lenght at the surface and servo is nearly equal so there is not a reduction in drive torque.
It is best to use 100% of the servo travel to get the desired control surface movement. Then you get the full amount of torque. It is the ratio of the arm lengths that matter, not their overall length.
Having setup a few gliders with these, I'll say they can be a pain to install, so you are not missing much.
Old 03-25-2021, 07:07 PM
  #261
cycross
cycross's Avatar
Am wondering where has the manufacturer landed with the solution for the vertical stabiliser flutter issue. Other than the straight-up CF overall usage to build the stabs, there hasn't been any further news about the part on linkages. Kris, which version of the stabiliser are you flying this FL season? My thoughts too about Looping31's case, whether an improvement was found somehow.
Old 03-25-2021, 08:27 PM
  #262
FenderBean
FenderBean's Avatar
Kris looked at mine at FL jets and said to not fly it, even with the new rudder drive units it has too much slop and said I should get new rudders and drive units. I think its the T joint not being the right size to what what they are cutting the drive units at. I'm consider dumping the the direct drive and doing a mod, Im just tired of dealing with it.
Old 03-26-2021, 07:18 AM
  #263
gunradd
My Feedback: (9)
gunradd's Avatar
im flying with the original system with the tighter drive units. It’s working fine and I’m flying her fast and hard.
Old 03-09-2023, 07:30 PM
  #264
David Jackson
My Feedback: (15)
Just curious, is the tighter rudder drive unit the only update to the T-One F-22? Never flew this model, and just realized it's been nearly three years since I put this plane on the shelf. Planning to get it flown this year, but would greatly appreciate any info regarding any vertical fin improvements made available by T-One.
Old 03-10-2023, 09:24 AM
  #265
FenderBean
FenderBean's Avatar
The new kit has carbon fiber rudders that are a bit heavier, but you really only need the updated drive Unit. I flew mine on the stock rudders with no issue just the updated drive units.
Old 03-30-2023, 11:08 AM
  #266
Spencer K
My Feedback: (14)
Hey guys, it seems as though the weapons doors are having trouble staying closed with the stock setup. anyone found a fix?
Old 03-31-2023, 09:23 AM
  #267
FenderBean
FenderBean's Avatar
it was a problem on my first I plan on addressing it with the next one. Its an angle problem, the cylinder is in a position that even when full closed it pulls open will the cylinder remains full closed. Only way to fix it is to move the air cylinder attachment point in the weapons bay.
