Reload this Page >
T-One Models F22 Raptor build thread
Old 07-27-2020, 04:42 AM
  #176
gunradd
My Feedback: (9)
gunradd's Avatar
Here is one of my landings. Its a very easy plane to land and fly.
Old 07-27-2020, 06:50 AM
  #177
David Jackson
My Feedback: (15)
Chris,
Just curious, what's the length of that runway? Our home field has a runway that is 400' , so this will be the main field from which my F-22 will fly. I don't think landing will be an issue, but not sure if more space might be needed for take offs.
David
Old 07-27-2020, 08:19 AM
  #178
gunradd
My Feedback: (9)
gunradd's Avatar
Originally Posted by David Jackson
Chris,
David
If you have clean runoffs you should be good. It will takeoff easy in 400 feet. The thrust vectoring gets her up fast. My runway is 700 feet. We have trees on the approach so i came in a little high. 400 feet should be ok for landing. Just need to be on your game.
Old 07-27-2020, 09:37 AM
  #179
gunradd
My Feedback: (9)
gunradd's Avatar
Here is some video.
Old 07-27-2020, 04:48 PM
  #180
ravill
ravill's Avatar
That is one swwwweeeeetttt take off! Nicely done!
Old 07-28-2020, 12:36 PM
  #181
DelGatoGrande
My Feedback: (23)
DelGatoGrande's Avatar
working on a scale cockpit
Old 08-05-2020, 12:06 PM
  #182
gunradd
My Feedback: (9)
gunradd's Avatar
Some more info on the flight controls.
On the first flights I was moving rudders in and it was picking the nose up and had nice drag.
These last flights I moved rudders out with flap and it causes it to pitch down allot. So I will change the rudders back to moving in with flaps. The real one moves them out after landing for speed brakes but I will just leave them in.
Old 08-05-2020, 03:50 PM
  #183
FenderBean
FenderBean's Avatar
Could make a mix with your brakes so they go out when you apply brakes which is nice since it will keep pressure on the nose for steering and then with no brakes applied and just flaps they can go in for take off. I thought they moved in for takeoff like the F-18
Old 08-06-2020, 03:26 AM
  #184
gunradd
My Feedback: (9)
gunradd's Avatar
They do move in for takeoff... I was watching videos of the real one but on the ground after landing they where always out so I did mine out. After more research they move in for takeoff landing until its braking.
I cant do a mix to move it in and out only one way. That is a gyro controlled surface and I only have one channel doing it with the smooth flight. So I will make them move in with the flaps down and leave it. The main gear is so far behind the CG it really does not need pressure on the nose gear anyway. Its got plenty.
Old 08-06-2020, 06:28 AM
  #185
FenderBean
FenderBean's Avatar
Roger, I will try to mix something for in my radio that pushes them out when throttle is addle, gear down and brakes are applied to prevent it happening in flight. I did something similar to the F-14 to prevent flaps with wings back.
Old 08-26-2020, 03:58 AM
  #186
gunradd
My Feedback: (9)
gunradd's Avatar
Some flight video from the owner and designer of the F22 in China. Mr Kim.
Old 08-26-2020, 08:58 AM
  #187
FenderBean
FenderBean's Avatar
Been having gear retraction issues on mine, any thoughts to a solution?
Old 08-26-2020, 09:34 AM
  #188
gunradd
My Feedback: (9)
gunradd's Avatar
What's it doing? Mine has never had issues accept I had one cylinder leaking so I pulled it off and it had a small metal shaving inside from the machining process. Cleaned it out and lubed and its worked perfect since. This is still the gear from the prototype.
Old 08-26-2020, 09:46 AM
  #189
FenderBean
FenderBean's Avatar
It just doesnt unlock well and have enough authority to close without help, down is fine, mains of course nose will break a finger lol. I have it on a two valve setup, so one puts pressure on the unlock and the other is for the gear only. I thought about shortening the spring that is on the unlock cylinder to make it easier but wasnt sure. I wanted to take the air cylinders apart to clean and re-lube but dont see a way to take them apart like you mention, im guessing the paint is covering up the seam.
Old 08-26-2020, 10:10 AM
  #190
gunradd
My Feedback: (9)
gunradd's Avatar
Removing the cylinders was not easy if I remember right and I would not do unless you have too. I have never had unlock issues. So you have the one valve unlock first then after with a sequencer you have a separate gear up valve? That unlock will work with pretty low pressure but it needs to unlock before the mains try and move or it will bind up. I tried to save a channel and just use an air restrictor on the mains so the unlock would happen first but it was not consistent so used a sequencer and it works fine.
Old 08-26-2020, 11:43 AM
  #191
FenderBean
FenderBean's Avatar
Yeah mine unlocks first then applies pressure via a different valve to the lift the gear
Old 08-28-2020, 05:59 PM
  #192
fotis kalevras
fotis kalevras's Avatar
fantastic model!
Old 09-06-2020, 11:14 AM
  #193
DelGatoGrande
My Feedback: (23)
Size:  10.6 KB Name:  IMG-6941.jpg
Size:  7.4 KB Name:  IMG-6942.jpg
ready !
Size:  65.0 KB Name:  final-closeup.png
and the full size :
Old 09-06-2020, 12:20 PM
  #194
gunradd
My Feedback: (9)
gunradd's Avatar
wow fantastic work!
Old 09-07-2020, 03:25 AM
  #195
DelGatoGrande
My Feedback: (23)
wow fantastic work!
Thank you !
..plus screens are functional
Video of the UFD "up frond display"
skunkwurk (09-08-2020)
Old 09-08-2020, 07:04 AM
  #196
skunkwurk
My Feedback: (18)
skunkwurk's Avatar
Nice!
Old 09-14-2020, 10:43 AM
  #197
DelGatoGrande
My Feedback: (23)
Originally Posted by skunkwurk
Nice!
...its getting better !
Switches close up , everything is scale down to the marking details
Old 09-14-2020, 09:34 PM
  #198
Remco45
Default LDG problem
Hi Fenderbean, were you able to solve the main LDG problem and if so, how?
Old 09-15-2020, 04:27 PM
  #199
FenderBean
FenderBean's Avatar
I havent had a chance to get back to it, working full time now so I havent had a chance to try. Rudders are are done now so once the gear is squared away it will be ready to go.
Old 10-03-2020, 07:55 AM
  #200
ddennison
My Feedback: (15)
Great thread and thank you to all who are sharing. I flew my Yellow for a bit, loved the way it flew, didn't like the takeoff. It was a little small as well. Im very interested to go ahead with this model.
It seems like you guys are working out the kinks. LG and slats sound like we still need to keep an eye on. Is there any future thought of electric gear?
Can we order without the doors for weapons? Id be happy with the weight savings and am more interested in short field flight characteristics than the (very nice) super scale stuff.
I usually build mine but how much can be done as "arf" - can we choose certain level of prefab?
Looking into the servos you used - Id certainly like the rudder spline to match
Last question - seems single with Y is the way to go?
Dave
