F-4 Phantom 1/8 scale Scratch Built
#76
Javad
No, it will fly. Paint it as you wish and I’ll get it off the ground and back down again 😉
I’ll check the ailerons properly so I don’t have to reverse half my brain again 😃
Dave
Dave
#78
Haha, I'll make this one taileron, with 4 flaps, so no chance you do test fly with revers aileron ,
Below my first jet, Dave did test fly & helped me to learn how to setup and fly jet , 15th October 2016,:
#79
Canopy,
Hello Guys,
Little progress on finishing planking on top of fuse, and making canopy. Next step would be to cover the fuse with 25gram glass fibre. Once I finish, I'll use this canopy as a plug to make a mould, would be a challenge as it would be my first time to make a mould
#84
Down thrust angle ?
Hello guys,
I'm thinking about down-thrust angle, as real one have, Any suggestion please?
Does down trust will help little with a heavy tail? I'm worried if I put Down Trust, it will change trim in low and high throttle !!! any suggestion please
Javad,
Javad,
#86
As you mentioned, turbines are relatively small, and tail pipes are 56mm in Diameter too, So do you think about 2-3 degree would be okay? or more!!
#88
Hello Kevin,
I'll go for 5 degree,
Assuming your F-4 is trim on 50% power, Does it then decline in full power? or nothing to be notice,
Javad,
#96
Vent on Ruder,
Little going on details, I made the vent& little detail on ruder,
F-4 has as many as details can pin me on my workshop forever, and I don't know how far I will go for details, but for sure I will do some of main details,
#99
