Reload this Page >
Jeti DS-12
Jeti DS-12
Old 09-10-2020, 09:21 PM
  #351
CARS II
My Feedback: (7)
CARS II's Avatar
Got it!
Thanks you to both.
Old 09-12-2020, 05:39 PM
  #352
CARS II
My Feedback: (7)
CARS II's Avatar
Finishing up the Turbinator set up, my Boomer is next, fallowed by the Reaction, they all get a 12 chl receiver, even if only 10 chl are needed, I like the 12 chl antennas better, DSM10 with a magnetic on/off switch, just waiting on those 900mhzNG back up receivers to complete my install for all of them, two batts, may try the wireless switches later, I got one but, will try it later.
Having lots of fun with the switch of brands, love the Jeti flexibility.
If I only had more free time at the moment.
Old 09-13-2020, 07:45 AM
  #353
ravill
ravill's Avatar
Carlos,
A nice safety thing when it comes to gyros that I like to use is a velcro strap to hold them down, on top of however you are attaching them.
Having a gyro come loose at certain portions of the flight, when you can not turn it off fast enough, will kill an airplane. Imagine a fast low pass or on final.....
Old 09-13-2020, 07:58 AM
  #354
CARS II
My Feedback: (7)
CARS II's Avatar
Didn't think of that, very good idea Raffy, I will add the Velcro to it.
Tks.
Old 09-15-2020, 10:46 PM
  #355
CARS II
My Feedback: (7)
CARS II's Avatar
Added the Velcro strap to the receiver and completed the assist set up by making the gain knob a digital trim, it can now be flown to adjust.
Moving on to the Boomer.
Old 09-16-2020, 12:17 AM
  #356
HarryC
Sadly, the Assist gyro is getting a lot of reports of acoustic interference from jet engines. You should ground test it before flying. With the engine running, switch the gyro on, turn up the gain, then slowly increase throttle one click at a time. Watch the control surfaces very closely for any signs of shimmering or larger glitches.
Old 09-16-2020, 01:42 AM
  #357
CARS II
My Feedback: (7)
CARS II's Avatar
I will do that check on all my assist installs and will report back.
Thank you Harry.
Old 09-16-2020, 02:11 AM
  #358
Bob_B
Bob_B's Avatar
These typically happens at a certain RPM not the entire range. By doing the test Harry suggests you will find the throttle setting.
BTW. The velcro strap may Exacerbate the problem. If the surface that you mounted the Rx to is a smooth hard material the foam tape will never loose its grip. I have never seen a gyro come loose from a 3D heli Install.
Old 09-16-2020, 02:56 AM
  #359
Dansy
My Feedback: (53)
Dansy's Avatar
I was going to say...Velcro and Velcro strap is not a good idea......should used the sticky double side foam pad it come with.
Old 09-16-2020, 04:25 AM
  #360
flyingboxer
Excellent Carlos..,!!! Great job, fantastic radio customization.! I definitely would like to do something similar. I just bought also a DS-12 coming from FrSky HORUS, and spektrum and JR XG11. Surely this jeti is the lightest and better so far.
This thread is awesome..! Makes me hooked to RCU. I was more inclined to RCGroups and FlyingGiants, because I thought that they were better, but the content of this thread is much better and teaching than the others. Thanks for nurturing it.
I did exactly the same mods you did. 3D wheel, switches changed, etc. just waiting for ZB/Esprit, to bring the anodized aluminum sliders to sale, to buy a pair. I have a black DS-12 so, in red those pair of sliders would look sick!..
un abrazo fuerte tocayo..!!
Carlos U
Old 09-16-2020, 06:40 AM
  #361
ravill
ravill's Avatar
If the assist gyro is suffering from this type of interference, then it doesn’t belong on a jet. I have 3 assists and they are on non turbine airplanes. And I have also heard this rumor. And why it’s so important to have an “off” setting if one is going to try to use one on a turbine.
And sorry to disagree with the gents above, but the risk of a gyro coming loose is too great to not strap it down. It may not have to be tight, but an extra layer of protection NEVER hurts.
Pretty much every jet is more expensive than a 3D heli, the helo’s have nice and clean carbon fiber to stick to and the helos just don’t go as fast as jets.
Edit: In all fairness, I doubt any airframe gets more "G" abuse than those 3D helis. The stuff those pilots can do are amazing!
Old 09-16-2020, 06:42 AM
  #362
flyingboxer
maybe with the tray that esprit/Zb sells, and the rubber o ring and this tray bolted to the wood board.
Old 09-16-2020, 08:01 AM
  #363
camss69
My Feedback: (46)
camss69's Avatar
I think he was mentioning the 3D heli because of the insanely violent (maybe I should say high G) maneuvers they put them through and the RX still doesn’t come loose with just the tape.
I only have 1 assist installed but I have two more in the bench waiting to go in. The one I have installed is using the 3D printed mount that esprit sells. It’s installed in a turbine and no issues so far with it after over 50 flights.
Bob_B (09-16-2020)
Old 09-16-2020, 09:40 AM
  #364
CARS II
My Feedback: (7)
CARS II's Avatar
Carlos, thank you for the nice words, if you would like some of the tape I used on my radio, send a pm and I will mail you 12" of it for your radio.
This thread is an international team effort, we have the best of the best posting on this thread, many thanks to them.
Ahh! Miami, haven't been there in years, will have to visit the family soon.
Old 09-16-2020, 09:47 AM
  #365
CARS II
My Feedback: (7)
CARS II's Avatar
As Raffy suggested, secured not tight.
100% agree with Daniel, double side tape is the way to go.
Old 09-16-2020, 09:56 AM
  #366
CARS II
My Feedback: (7)
CARS II's Avatar
The suggested step to check for acoustics interferince is a must do, I think this check becomes crucial as the bearings get loose and this check should be performed a few times a year.
Old 09-16-2020, 12:56 PM
  #367
flyingboxer
Thanks a lot for your offer. My radio already have it in place. Thanks. Please show pictures of your jet once you manage to set it up.
regards.
Carlos U
Old 09-16-2020, 02:30 PM
  #368
CARS II
My Feedback: (7)
CARS II's Avatar
C
Do you something specific that you would like to see from the jet set up ( crow, on and off, how to make sure the servos are going the right direction when the gyro is correcting.
Old 09-17-2020, 01:28 PM
  #369
CARS II
My Feedback: (7)
CARS II's Avatar
Here you will find a few things that yourJeti radio can do for you, pick the ones that you think you can use.
https://www.helifreak.com/showthread.../topics/732981
Old 09-17-2020, 07:05 PM
  #370
CARS II
My Feedback: (7)
CARS II's Avatar
If the double side tape that is holding the receiver to the floor doesn't do the trick then, I will get me a receiver holder with the O ring and will give it a go again.
Old 09-17-2020, 07:33 PM
  #371
camss69
My Feedback: (46)
camss69's Avatar
That's what I use.
Old 09-17-2020, 07:48 PM
  #372
CARS II
My Feedback: (7)
CARS II's Avatar
Looks like I will be adding them to each one of my receivers.
Old 09-17-2020, 08:07 PM
  #373
CARS II
My Feedback: (7)
CARS II's Avatar
Not going to wait, just order 4 of them.
Old 09-17-2020, 09:31 PM
  #374
HarryC
As much as possible, you should only use the double sided tape to mount a gyro. This is in the instructions of every brand of gyro, not just Assist. Do not use hard mounts, clips, velcro straps etc. Only use the foam tape. There is a reason that every brand of gyro comes with foam tape, take the hint! If you attach it to a clean smooth surface (not bare wood) it doesn't come off.
Old 09-18-2020, 01:48 AM
  #375
Bob_B
Bob_B's Avatar
If you have to mount the assist to a balsa surface cut a piece of 1/16” ply To the size needed and prepare the surface using thin CA glue. I usually coat it two - three times letting it dry between applications. The goal is to create a smooth glass like surface.
then glue the ply plate to the airframe and its ready for the assist to be mounted.
