Reload this Page >
Jeti DS-12
Jeti DS-12
Old 10-30-2020, 12:04 PM
  #401
CARS II
My Feedback: (7)
CARS II's Avatar
One thing I noticed at the last jet meet I attended ( Fresno ) the increasing quantity of jet guys that have switched to fly with Jeti radio systems, one of the guys flying the XL F-16 was switching it to Jeti on our last day.
Don't be left behind, jump the fence soon 😁😁
Old 10-30-2020, 09:36 PM
  #402
ravill
ravill's Avatar
Good find Carlos!!
Old 11-03-2020, 04:47 PM
  #403
CARS II
My Feedback: (7)
CARS II's Avatar
Ok, this is a guide for those that are looking how to start their first set up, it will be a bit different from modeler to modeler depending on their needs and choices.
Continuing with the learning process, here is my basic set up for a new model, my 3 jets set up are identically, I'm highlighting the key points, the details of the steps I do by memory, I figured out I only need the steps/functions as a guide to do the set up, after you have read all you can read and watched all the vids, learning how others have done their set up and why they like it that way is the next step on the learning ladder.
Reminder, there is more than one way how to get the same results.
New model
Basic properties
Bind receiver
Calibrate receiver
Add functions ( steer, brakes, smoke, Gyro OFF, Gyro Gain, Gyro FL Mode )
Functions menu
Remove flap switch
Assign P3 to steer
Assign SC to Gear
Assign SD to brakes
Assign SB to smoke
Assign P6 to Gyro OFF
Assign trim Tr6 to Gyro Gain
Assign SA to Gyro Mode
Dual rates/expo
Assign SF to Ail, Elev
Assign SC to Steer
Digital trim
Remove trim from Rudd
X trim controls
Assign P7 to Tr6
Tr6 mode to "S"
Throttle to -100% steps
Assign center to Elev
Assign thro-Low to Throttle
Elev, Ail mode to "S"
FL Modes
Add 2 FL Modes
Name: Cruise, TO, Land
Slow to 1.5 sec
Assign SA to cruise, TO, Land
Flaps
Butterfly/Crow
Assign Log Max control
Mode to "S"
Servo set up
Adjust Ail via Ail Differential
Adjust Elev via Ailevator
Old 11-03-2020, 05:08 PM
  #404
CARS II
My Feedback: (7)
CARS II's Avatar
And here is my add ons list which will grow immensely with time.
Add Timer
Add Display Telemetry
Old 11-03-2020, 11:45 PM
  #405
HarryC
You only need to add 2 flight modes, just use default as one of your modes
Old 11-04-2020, 09:54 AM
  #406
CARS II
My Feedback: (7)
CARS II's Avatar
You are correct Harry, changed from, add 3 to add 2 FL mods and some miss spell corrected.
Tks.
Old 11-05-2020, 08:59 AM
  #407
ZB
The Voltario T60 is a high performance digital dual redundant battery switch with advanced telemetry features and touch switch functionality. It combines a backup battery charging circuit and telemetry with Touch w/LED (Included), optional Sliding, Wireless (R3/RSW) or mechanical switch functionality in a single device.
The T60 is ideal for mid-size models where high-voltage servos are used without voltage stabilization. It provides telemetry and monitors Voltage/V, Capacity/mAh, and Current/A (Dual Rx Batteries, or BEC w/Backup Battery) of both power inputs.
Specifications and Features
- Intelligent dual battery backer/multiplexer with configurable voltage switchover threshold.
- Touch switch function (Included), Optional Mechanical, Sliding or Wireless (R3/RSW).
- Duplex EX, Futaba S.Bus2, Multiplex MSB, Graupner Hott telemetry support.
- Optional charging of the secondary/backup battery with capacity protection limits.
- Remembers the last operating state if the battery is accidentally disconnected.
https://www.espritmodel.com/elite-el...ba-s-bus2.aspx
ID:	2268545 Click image for larger version
Old 11-05-2020, 02:22 PM
  #408
CARS II
My Feedback: (7)
CARS II's Avatar
Third set up almost done, this time is the Reaction 54 been converted to Jeti with Assist, It will fly this Sat.
Old 11-05-2020, 07:14 PM
  #409
CARS II
My Feedback: (7)
CARS II's Avatar
All done!! and I didn't even break a sweat 😁 very simple to do, gyro and all.
Old 11-06-2020, 04:34 PM
  #410
CARS II
My Feedback: (7)
CARS II's Avatar
The Re-maiden of the Reaction with Jeti is done!
All went well, after all the proper checks, including the acustic checks on all 3 axis, the acustic check didn't produce any significant vibrations, hardly any and it was done with the gyro up to +100% ( per Harry's recommendations ) the control surfaces were also observed during the test and that also didn't produce any movement of the surfaces.
First, the trim flight, on the ground the main chls were re-learned and we prepared for the gyro on flight, the gyro on flight was excellent, I will have to increase the gyro sensitivity as I get more flights in.
All in all, I have been having an excellent experience with the Jeti receives with the Assist gyro build in.
Big thanks to my friend Nick for swinging by the field after work to help me with the re-maiden.
Old 11-06-2020, 05:20 PM
  #411
ravill
ravill's Avatar
Nice Carlos!!
Old 11-06-2020, 06:23 PM
  #412
camss69
My Feedback: (46)
camss69's Avatar
All went well, after all the proper checks, including the acustic checks on all 3 chls, the acustic check didn't produce any significant vibrations, hardly any and it was done with the gyro up to +100% ( per Harry's recommendations ) the control surfaces were also observed during the test and that also didn't produce any movement of the surfaces.
Big thanks to my friend Nick for swing by the field after work to help me with the re-maiden.
Congrats on the 2 perfect flights! Always fun hanging at the field!
Old 11-06-2020, 06:53 PM
  #413
CARS II
My Feedback: (7)
CARS II's Avatar
Thank you Raffy and Nick.
The show is on next Thursday.
Old 11-06-2020, 08:18 PM
  #414
ravill
ravill's Avatar
Yes, it is!!!
Old 11-11-2020, 11:21 AM
  #415
CraigG
My Feedback: (40)
CraigG's Avatar
I'm going to give an Assist receiver a try on my next model, however, it has flaperons (ailerons also function as flaps). Will I lose aileron stabilization when the flaps extend? I'm thinking it might if the assist rx sees the "aileron" movement as a "stick" input and reduces stabilization due to "stick priority" settings. Hoping Harry sees this and can comment.
Thanks......Craig
Old 11-11-2020, 02:05 PM
  #416
CARS II
My Feedback: (7)
CARS II's Avatar
I doubt you'll loose it, I'm sure the Jeti engineers thought about that and you get to keep the stabilization on the Ail.
Old 11-11-2020, 02:06 PM
  #417
CARS II
My Feedback: (7)
CARS II's Avatar
Maybe Wayne has some thoughts about that.
Old 11-11-2020, 02:22 PM
  #418
CraigG
My Feedback: (40)
CraigG's Avatar
Been fooling around a little programming the new jet and was surprised to find Jeti does not have a "Flaperon" option in the wing type menu. Figured out a way to do it (I think) in the Butterfly/Flaps menu but it wasn't easy. None of Harry's or the Espirit videos (that I could find) address specifically how to do it with a 3-position (i.e. flap) switch. I'm going to want fixed/different gain values for each flap position (after I find good gain settings), but again, can't seem to find specifically how to do that in Harry's videos. I'm sure there is a way to do it but may need help from the experts.
Old 11-11-2020, 03:22 PM
  #419
CARS II
My Feedback: (7)
CARS II's Avatar
Here is the vid from Esprit about Flaprons.
Old 11-11-2020, 03:27 PM
  #420
CARS II
My Feedback: (7)
CARS II's Avatar
Here is Harry's vid on how to set up Flaps with Crow on the Ail.
Old 11-11-2020, 03:30 PM
  #421
CARS II
My Feedback: (7)
CARS II's Avatar
I would set it up the same way as indicated on Harry's vid, using the 3 flight modes, this way you get to use a 3 position switch, instead of Ail up on Landing, do Ail down.
Old 11-11-2020, 03:44 PM
  #422
CARS II
My Feedback: (7)
CARS II's Avatar
Here is the vid on how to set up the 3 flight modes, one-step you'll have to do in Funtions is to remove the Flap's switch/control, the 3 position switch from the FL mode will control the Flaperons.
Old 11-11-2020, 04:44 PM
  #423
wfield0455
My Feedback: (7)
wfield0455's Avatar
The Butterfly menu should work fine for flaperons. Here is a list ot the things I'd to to get it working with a 3 position switch.
1) Create Flap based flight modes such as Normal, Half and Full (the name isn't important) selected by the desired 3 position switch.
2) Make Butterfly flight mode specific by changing it from G to S.
3) In the Butterfly menu set the switch field to LOG_MAX, which is located at the very bottom of the logical switch choice in the switch selection menu. This is important as the switch field value scales the Butterly function output. For example, if you select a 3 position switch with values of -100,0,+100 then ONLYthe +100% position will allow the ailerons to be moved as flaps because 0% or a negative %
results in no movement no matter what value you provide in the Aileron field of the butterfly menu. LOG_MAX always evaluates to +100% so by setting the switch field to that you can set a value for each flight mode that will result in the correct movement.
4) Select each flight mode and adjust the Aileron field in the Buttefly menu for the desired flap deflection for that flight mode.
Done.
That is a fairly high level description off the top of my head so I may have mssed something. Just look things over and if something doesn't make sense feel free to ask.
Also, as for the Assit receiver with flaperons, I haven't personally tried it but I think you should be fine. As far as the Assist is concerned only has Ailerons and there is no need to have an actual flap function. One thing to remember, is when you move the sticks associated with each control axis select the highest rate for each function during stick calibration to ensure that the stick priority works properly.
Old 11-12-2020, 04:24 AM
  #424
HarryC
I have just had a play with the Assist, it is clever enough to recognise the difference between aileron control and flaperon control, so even at 100% flaperon travel it does not apply the stick priority, and still gives full stabilisation as ailerons.
Old 11-12-2020, 04:29 AM
  #425
CraigG
My Feedback: (40)
CraigG's Avatar
Done.
Thanks Carlos, Wayne and Harry!! The videos and explanations were very helpful. The trick was setting the Control switch to LOG_MAX so the ailerons would respond as flaps in both the takeoff and land position. The only issue I have now is that the "flaps" move instantly to the selected value. The Delay settings in the Butterfly/Flaps menu don't seem to have any effect. I would like to have the flaps move slowly but obviously don't want to change the speed of the "Ailerons". Any suggestions?
Thanks again for the help........Craig
